[petsc-dev] style guide
Smith, Barry F.
bsmith at mcs.anl.gov
Tue Feb 20 10:25:53 CST 2018
> On Feb 20, 2018, at 10:21 AM, Kokron, Daniel S. (ARC-606.2)[CSRA, LLC] <daniel.s.kokron at nasa.gov> wrote:
> Developers,
> I am working with a CFD code that makes heavy use of PETSc. The case spends most of it's time dealing with 9x9 matrices. I spent some time adding kernels for dealing with 9x9 matrices under src/mat/impls/baij/seq. I have also re-written chunks of src/vec/vec/impls/seq/dvec2.c to reduce memory transfer requirements. Overall, I'm seeing about a 10% speedup for this case. I'd like to submit these changes for inclusion into a future release.
Thanks for your potential contributions.
> I have followed style guide excepts that I still have a few chunks of code in several 'include' files located under my src/vec/vec/impls/seq directory. They currently have names like Case3.c and Case16.c. Should I just move these to the top level include directory and be done with it
We definitely don't want them in the top level include files.
> or convert them to 'defines' and put them in some other location?
We prefer to PETSC_STATIC_INLINE functions over defines if that works.
You could make a pull request with your current code and then we'd know exactly what it looks like and could make concrete suggestions for changes.
Barry
> Daniel Kokron
> NASA Ames (ARC-TN)
> SciCon group
