[petsc-dev] petsc/master: unable to link in C++ with last night PETSC_WITH_EXTERNAL_LIB variable changes
Éric Chamberland
Eric.Chamberland at giref.ulaval.ca
Sat Feb 10 19:31:27 CST 2018
Le 18-02-10 à 17:44, Jeff Hammond a écrit :
> Indeed, everybody should compiler MPI codes with
> "-DMPICH_SKIP_MPICXX=1 -DOMPI_SKIP_MPICXX=1" now.
> I'll ask MPICH and Open-MPI to switch the default to exclude C++ bindings.
Will definitely switch my default compiling options right now.
And I agree that it is relevant to switch that by default for all MPI
distributions. Thanks for forwarding!
Eric
> Jeff
> Jeff Hammond
> jeff.science at gmail.com <mailto:jeff.science at gmail.com>
> http://jeffhammond.github.io/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180210/4761bd20/attachment.html>
