[petsc-dev] petsc/master: unable to link in C++ with last night PETSC_WITH_EXTERNAL_LIB variable changes
Éric Chamberland
Eric.Chamberland at giref.ulaval.ca
Sat Feb 10 19:29:28 CST 2018
Le 18-02-10 à 16:48, Jed Brown a écrit :
> That's sad, but is this not avoided by defining OMPI_SKIP_MPICXX before
> including mpi.h? (There is also MPICH_SKIP_MPICXX if you want.) This
> is done by default in petscsys.h, but you might not include it in that
> file or don't include it before mpi.h is included.
Ok, didn't knew about this... I think this is definitely a good
solution!!! :)
Thanks again!
Eric
