[petsc-dev] WHO BROKE THE TRIANGLE BUILD
Smith, Barry F.
bsmith at mcs.anl.gov
Wed Feb 7 09:27:22 CST 2018
Lots of stuff is broken if you use std=c99 just look at yesterday's next.
> On Feb 7, 2018, at 9:08 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Feb 8, 2018 at 2:02 AM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> That is yesterday's build. Today's next look ok.
> I had accidentally made PETSc use std99 compiler for everything include external libraries
> Do you have problems with the most recent branches right now?
> Pulling and checking. I has not pulled from yesterday.
> Does that mean Triangle is broken for stdc99? One more thing to fix.
> Matt
> > On Feb 7, 2018, at 8:52 AM, Matthew Knepley <knepley at gmail.com> wrote:
> > On Thu, Feb 8, 2018 at 1:49 AM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> > If you provide absolutely NO information about the problem you cannot expect a polite helpful response, you will be ignored. Broke means nothing!
> > http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2018/02/06/configure_next_arch-linux-opt-misc_el6.log
> > Matt
> > > On Feb 7, 2018, at 8:48 AM, Matthew Knepley <knepley at gmail.com> wrote:
> > > That has worked for a decade.
> > > Matt
> > > What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> > > -- Norbert Wiener
> > > https://www.cse.buffalo.edu/~knepley/
> > -- Norbert Wiener
> -- Norbert Wiener
