[petsc-dev] WHO BROKE THE TRIANGLE BUILD
    Matthew Knepley
    knepley at gmail.com
    Wed Feb  7 09:08:20 CST 2018
On Thu, Feb 8, 2018 at 2:02 AM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>   That is yesterday's build. Today's next look ok.
>    I had accidentally made PETSc use std99 compiler for everything include
> external libraries
>    Do you have problems with the most recent branches right now?
Pulling and checking. I has not pulled from yesterday.
Does that mean Triangle is broken for stdc99? One more thing to fix.
  Matt
> > On Feb 7, 2018, at 8:52 AM, Matthew Knepley <knepley at gmail.com> wrote:
> > On Thu, Feb 8, 2018 at 1:49 AM, Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
> >   If you provide absolutely NO information about the problem you cannot
> expect a polite helpful response, you will be ignored. Broke means nothing!
> > http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/
> 2018/02/06/configure_next_arch-linux-opt-misc_el6.log
> >    Matt
> > > On Feb 7, 2018, at 8:48 AM, Matthew Knepley <knepley at gmail.com> wrote:
> > > That has worked for a decade.
> > >    Matt
> > > What most experimenters take for granted before they begin their
> experiments lead.
> > > -- Norbert Wiener
> > > https://www.cse.buffalo.edu/~knepley/
> experiments lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180208/d5b993c7/attachment-0001.html>
