[petsc-dev] ARG_MAX and linking
Jed Brown
jed at jedbrown.org
Tue Feb 6 11:17:20 CST 2018
Oh good. So maybe this conditional also needs to recognize msys2 so we
can also add this flag for Pierr's msys2 with gcc.
Satish Balay <balay at mcs.anl.gov> writes:
> gmakefile has:
> # implies shared libraries with MS compilers
> ifeq ($(SL_LINKER_FUNCTION),-LD)
> $(OBJDIR)/%.o : CCPPFLAGS+=-Dpetsc_EXPORTS
> endif
> Sure - the comment is misleading - it could be updated to say 'gmakefile' instead of 'CMake'
> Satish
> On Tue, 6 Feb 2018, Jed Brown wrote:
>> If it's a __declspec(dllexport) issue, it's probably just not being
>> handled correctly in petscsys.h. Actually, it could be this junk which
>> much be obsolete because we don't use CMake to build PETSc and also
>> don't define petsc_EXPORTS.
>> include/petscsys.h-#if defined(petsc_EXPORTS) /* CMake defines this when building the shared library */
>> include/petscsys.h:# define PETSC_VISIBILITY_PUBLIC PETSC_DLLEXPORT
>> include/petscsys.h-#else /* Win32 users need this to import symbols from petsc.dll */
>> include/petscsys.h-# define PETSC_VISIBILITY_PUBLIC PETSC_DLLIMPORT
>> include/petscsys.h-#endif
>> Pierre Jolivet <pierre.jolivet at enseeiht.fr> writes:
>> > I’m on master.
>> > Thanks, I think this is the way to go, though I’m now seeing a lot of undefined references, like there http://mingw-users.1079350.n2.nabble.com/imp-prefixes-when-linking-td7386007.html <http://mingw-users.1079350.n2.nabble.com/imp-prefixes-when-linking-td7386007.html>
>> >> On 6 Feb 2018, at 2:05 PM, Jed Brown <jed at jedbrown.org> wrote:
>> >> What branch are you on? I wonder if this is exacerbated by Scott's
>> >> "absolute path". You can configure --with-single-library=0 which will
>> >> link a separate libpetscsys, libpetscvec, etc.
>> >> There are Cygwin recipes in gmakefile that create argument files that
>> >> the linker reads as @args. We could use $(file > args, $^) to write
>> >> them with arbitrarily long command lines.
>> >>> Hello,
>> >>> I’m trying to compile PETSc with msys2 and MS MPI.
>> >>> Everything works out almost flawlessly, except when linking. Indeed, you generate a nice line of
>> >>> $ wc /tmp/cl
>> >>> 2 1234 69041 /tmp/cl
>> >>> 69041 characters, but
>> >>> $ getconf.exe ARG_MAX
>> >>> 32000
>> >>> Thus, sadly, the make fails with the following error
>> >>> /usr/bin/sh: /mingw64/bin/gcc: Argument list too long
>> >>> Do you know of a work around? Anyway to link the full library as multiple smaller libraries (I think you did that for some version X.Y with X << 3, didn’t you?)?
>> >>> Thanks,
>> >>> Pierre
