[petsc-dev] ARG_MAX and linking
Satish Balay
balay at mcs.anl.gov
Tue Feb 6 10:55:09 CST 2018
gmakefile has:
# implies shared libraries with MS compilers
ifeq ($(SL_LINKER_FUNCTION),-LD)
$(OBJDIR)/%.o : CCPPFLAGS+=-Dpetsc_EXPORTS
endif
Sure - the comment is misleading - it could be updated to say 'gmakefile' instead of 'CMake'
Satish
On Tue, 6 Feb 2018, Jed Brown wrote:
> If it's a __declspec(dllexport) issue, it's probably just not being
> handled correctly in petscsys.h. Actually, it could be this junk which
> much be obsolete because we don't use CMake to build PETSc and also
> don't define petsc_EXPORTS.
> include/petscsys.h-#if defined(petsc_EXPORTS) /* CMake defines this when building the shared library */
> include/petscsys.h:# define PETSC_VISIBILITY_PUBLIC PETSC_DLLEXPORT
> include/petscsys.h-#else /* Win32 users need this to import symbols from petsc.dll */
> include/petscsys.h-# define PETSC_VISIBILITY_PUBLIC PETSC_DLLIMPORT
> include/petscsys.h-#endif
> Pierre Jolivet <pierre.jolivet at enseeiht.fr> writes:
> > I’m on master.
> > Thanks, I think this is the way to go, though I’m now seeing a lot of undefined references, like there http://mingw-users.1079350.n2.nabble.com/imp-prefixes-when-linking-td7386007.html <http://mingw-users.1079350.n2.nabble.com/imp-prefixes-when-linking-td7386007.html>
> >> On 6 Feb 2018, at 2:05 PM, Jed Brown <jed at jedbrown.org> wrote:
> >> What branch are you on? I wonder if this is exacerbated by Scott's
> >> "absolute path". You can configure --with-single-library=0 which will
> >> link a separate libpetscsys, libpetscvec, etc.
> >> There are Cygwin recipes in gmakefile that create argument files that
> >> the linker reads as @args. We could use $(file > args, $^) to write
> >> them with arbitrarily long command lines.
> >>> Hello,
> >>> I’m trying to compile PETSc with msys2 and MS MPI.
> >>> Everything works out almost flawlessly, except when linking. Indeed, you generate a nice line of
> >>> $ wc /tmp/cl
> >>> 2 1234 69041 /tmp/cl
> >>> 69041 characters, but
> >>> $ getconf.exe ARG_MAX
> >>> 32000
> >>> Thus, sadly, the make fails with the following error
> >>> /usr/bin/sh: /mingw64/bin/gcc: Argument list too long
> >>> Do you know of a work around? Anyway to link the full library as multiple smaller libraries (I think you did that for some version X.Y with X << 3, didn’t you?)?
> >>> Thanks,
> >>> Pierre
