[petsc-dev] petsc/master: mkl_cpardiso.c broken
    Éric Chamberland
    Eric.Chamberland at giref.ulaval.ca
    Sat Feb  3 07:21:24 CST 2018
Thanks Barry,
It is compiling now! :)
I didn't installed MKL myself, but our IT guy told me that you have to
select something like "cluster" or "hpc" when installing it, then you
will have cluster pardiso within the installed MKL libs.
Anyway, thanks again!
Eric
Le 18-02-02 à 20:42, Smith, Barry F. a écrit :
>   Eric,
>     Thanks for the report. I believe I have fixed the problem in master.
>     Unfortunately we do not have a copy of mkl_cpardiso so maintaining the interface is not trivial.
>     Barry
>> On Jan 31, 2018, at 2:39 PM, Eric Chamberland <Eric.Chamberland at giref.ulaval.ca> wrote:
>> Hi,
>> just to let know that since yesterday or before yesterday, I have errors in mkl_cpardiso.c on petsc/master:
>> http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2018.01.31.02h00m01s_make.log
>> other logs:
>> http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2018.01.31.02h00m01s_configure.log
>> http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2018.01.31.02h00m01s_RDict.log
>> http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2018.01.31.02h00m01s_CMakeLists.txt
>> Thanks,
>> Eric
