[petsc-dev] [petsc-users] Error during PETSc build on Edison
Thu Feb 1 11:14:50 CST 2018
check 'make test' [it runs 'testex19' in src/snes/examples/tutorials]
As refered to earlier - this ex3.c can be run with -nox option
Satish
you can runOn Thu, 1 Feb 2018, Amneet Bhalla wrote:
> Got it. What example should I try to see PETSc is working?
> On Thu, Feb 1, 2018 at 9:00 AM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> > ex3.c has
> >    ierr =
> > PetscViewerDrawOpen(PETSC_COMM_WORLD,0,0,0,0,400,400,&monP.viewer);CHKERRQ(ierr);
> > so it is going to require that some Draw implementation is available.
> > Since PETSc was apparently configure explicitly without support for x
> > windows there is no Draw support hence the code has to stop with an error
> > message. In other words this example requires X
> >   Barry
> > > On Feb 1, 2018, at 10:51 AM, Amneet Bhalla <mail2amneet at gmail.com>
> > wrote:
> > > I am getting this if I run snes/examples/tutorial/ex3 manually in
> > interactive session.
> > > [ex3 is a placeholder]
> > > On Thu, Feb 1, 2018 at 8:46 AM Smith, Barry F. <bsmith at mcs.anl.gov>
> > wrote:
> > >   Where are you getting these errors from? Some PETSc tests? Your own
> > code?
> > > > On Feb 1, 2018, at 10:32 AM, Amneet Bhalla <mail2amneet at gmail.com>
> > wrote:
> > > > Ok, and how to get rid of runtime error like
> > > > [0]PETSC ERROR: PETSc installed without X windows, Microsoft Graphics,
> > OpenGL ES, or GLUT/OpenGL on this machine
> > > > configure with --with-x=0?
> > > > On Thu, Feb 1, 2018 at 8:06 AM, Satish Balay <balay at mcs.anl.gov>
> > > > > P.S: I was also mucking with cray-petsc. However, I could not use it
> > > > > in my application. Cray-petsc is built with parallel hdf5 and some
> > > > > of the libraries I need use serial hdf5. At runtime, the application
> > > > > picks parallel hdf5 and the application crashes :-(. I tried this on
> > > > > my laptop also and got the same result.
> > > > > I think the only way out is to build my own version of PETSc without
> > > > > (parallel) hdf5.
> > > > Sure - its best to install petsc from source - for such special
> > requirements.
> > > > Satish
> > > > --Amneet
> > > --Amneet
> --Amneet
