[petsc-dev] [petsc-users] Error during PETSc build on Edison
Satish Balay
balay at mcs.anl.gov
Thu Feb 1 10:01:21 CST 2018
On Thu, 1 Feb 2018, Amneet Bhalla wrote:
> OK, I am now trying with INTEL compilers (as the GNU didn't seem to run the
> snes example manually).
What error do you get? Are you refering to the 'gethostbyname'
warning? You can ignore it. It shouldn't affect your run.
If you really want to get rid of it - you would have to edit
PETSC_ARCH/include/petscconf.h [after configure is run] - and remove
the lines related to PETSC_USE_SOCKET_VIEWER
And then rebuild the libraries.
> Now I am getting error with fortran and C++ linkage. See the configure.log
/tmp/petsc-pUSgZ5/config.compilers/cxxobj.o:(.eh_frame+0x11): undefined reference to `__gxx_personality_v0'
You need an additional option 'LIBS=-lstdc++'
Satish
> On Mon, Jan 29, 2018 at 9:13 PM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> > > On Jan 29, 2018, at 11:11 PM, Amneet Bhalla <mail2amneet at gmail.com>
> > wrote:
> > > I see. It compiled and linked on the frontend quickly. although with a
> > warning
> > > /global/homes/a/apbhalla/softwares/PETSc-BitBucket/
> > PETSc/linux-opt/lib/libpetsc.a(send.o): In function `PetscOpenSocket':
> > > send.c:(.text+0x346): warning: Using 'gethostbyname' in statically
> > linked applications requires at runtime the shared libraries from the glibc
> > version used for linking
> > > /usr/bin/rm -f ex3.o
> > Sadly this message will still be there long after we are all dead,
> > assuming Cray is still in business.
