[petsc-dev] mkl_cpardiso.c warnings
    Matthew Knepley
    knepley at gmail.com
    Sat Dec 15 09:47:10 CST 2018
Yep, we found these. I am going to make a PR. Thanks for reporting.
   Matt
On Fri, Dec 14, 2018 at 9:17 PM Eric Chamberland via petsc-dev <
petsc-dev at mcs.anl.gov> wrote:
> Hi,
> I just noticed there are warnings at compile time for some mkl_cpardiso.c
> routines:
> /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/mat/impls/aij/mpi/mkl_cpardiso/mkl_cpardiso.c: In function ‘MatDestroy_MKL_CPARDISO’:
> /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/mat/impls/aij/mpi/mkl_cpardiso/mkl_cpardiso.c:236:7: warning: passing argument 16 of ‘cluster_sparse_solver’ from incompatible pointer type [enabled by default]
>        (int*)&mat_mkl_cpardiso->err);
> and some more, full log here:
> http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2018.12.14.09h24m33s_make.log
> and configure log:
> http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2018.12.14.09h24m33s_configure.log
> Thanks,
> Eric
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20181215/2b38dd00/attachment.html>
