[petsc-dev] mkl_cpardiso.c warnings
    Eric Chamberland
    Eric.Chamberland at giref.ulaval.ca
    Fri Dec 14 20:17:05 CST 2018
I just noticed there are warnings at compile time for some
mkl_cpardiso.c routines:
/pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/mat/impls/aij/mpi/mkl_cpardiso/mkl_cpardiso.c: In function ‘MatDestroy_MKL_CPARDISO’:
/pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/mat/impls/aij/mpi/mkl_cpardiso/mkl_cpardiso.c:236:7: warning: passing argument 16 of ‘cluster_sparse_solver’ from incompatible pointer type [enabled by default]
        (int*)&mat_mkl_cpardiso->err);
and some more, full log here:
http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2018.12.14.09h24m33s_make.log
and configure log:
http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2018.12.14.09h24m33s_configure.log
Eric
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20181214/a3703c6b/attachment.html>
