[petsc-dev] Unneeded check in TSSetUp?
    Stefano Zampini
    stefano.zampini at gmail.com
    Mon Dec 10 06:35:40 CST 2018
In TSSetUp, current master has
if (!ts->vec_sol) SETERRQ(PETSC_COMM_SELF,PETSC_ERR_ARG_WRONGSTATE,"Must
call TSSetSolution() first");
but the function apparently does not make use of it. Would it be safe to
remove the check?
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20181210/9708f229/attachment.html>
