[petsc-dev] Docker images and NERSC's Shifter
Jed Brown
jed at jedbrown.org
Sun Dec 9 18:38:23 CST 2018
The PETSc and FEniCS Dockerfiles and linked images here might be of
interest to anyone running at an HPC facility that supports NERSC's
Shifter.
https://github.com/jedbrown/jedbrown-dockerfiles
IMO, Shifter is far superior to any other HPC deployment mechanism and
really should be supported everywhere. Using SLURM, it boils down to
running (once)
shifterimg pull docker:jedbrown/petsc:latest
then
sbatch --image docker:jedbrown/petsc:latest ...
with
srun -n 64 shifter ./your-petsc-app
No need to futz with HPC build environments, modules, etc. You can
build in the Shifter environment on a login node (see README). If you
must use Python or other shared libraries, performance at scale is
better (https://docs.nersc.gov/development/shifter/overview/) than any
other low-hassle Python deployment technique.
Comments welcome. I think we should consider automating the publishing
of nightly updates for 'maint' and 'master', perhaps with a few common
build configurations (int64, etc.).
You'll notice that the Dockerfiles have some manual repairs for
overzealous RPATH. We should have a configure option to avoid RPATH,
and perhaps default to not using RPATH for any paths that don't need it
(i.e., those that are already managed by the system ldconfig).
