[petsc-dev] configure issues with new MKL and --with-mkl_sparse_optimize=0
    Matthew Knepley
    knepley at gmail.com
    Mon Dec  3 19:43:20 CST 2018
On Mon, Dec 3, 2018 at 8:35 PM Mills, Richard Tran via petsc-dev <
petsc-dev at mcs.anl.gov> wrote:
> Sorry, everyone, for how long it took me to have time to get back to this.
> I tried the change I suggested in my previous message, but configure fails
> with
>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> details):
> Did not find package MKL_SPARSE_OPTIMIZE needed by mkl_sparse_sp2m.
> Enable the package using --with-mkl_sparse_optimize
> Does this happen because I have specified that this is a "look for by
> default" package? What I'd like to happen is that this package be looked
> for my default, in fact, but if MKL_SPARSE_OPTIMIZE is not present or
> disabled, then I'd like the test for mkl_sparse_sp2m to fail gracefully and
> configure to continue. That is: I don't want the fact that I am looking for
> this package automatically to imply that it HAS to be there. Is there any
> easy way to get this behavior?
Put it in the optional packages list. Then check explicitly that it was
found in the sp2m configure method.
    Matt
> --Richard
> On 11/27/18 2:15 PM, Smith, Barry F. wrote:
> On Nov 26, 2018, at 6:12 PM, Mills, Richard Tran via petsc-dev <petsc-dev at mcs.anl.gov> <petsc-dev at mcs.anl.gov> wrote:
> Hi Stefano,
> Apologies for the slow reply; I was out for the US Thanksgiving Holiday.
> You've found an error in the logic for the MKL configure tests: Your MKL does indeed have mkl_sparse_sp2m(), but since this depends on having mkl_sparse_optimize() and you have specified '--with-mkl_sparse_optimize=0', PETSC_HAVE_MKL_SPARSE_SP2M either ought to not be defined, or in my AIJMKL code I should only enable the SP2M code if PETSC_HAVE_MKL_SPARSE_OPTIMIZE is defined. I think I like the former option better. For those more familiar with BuildSystem than I am, I think I can do this by putting the following in setupDependencies() in mkl_sparse_sp2m.py:
>     self.mkl_sparse_optimize  = framework.require('config.packages.mkl_sparse_optimize', self)
>     self.deps                           = [self.blasLapack,self.mkl_sparse_optimize]
>     Looks ok to me. Make a pull request with Satish as a reviewer.
>    Barry
> Is that all that is required?
> --Richard
> On 11/21/18 10:59 PM, Stefano Zampini wrote:
> Richard,
> I just noticed that PETSc master does not build with the options
>     '--with-mkl_pardiso-dir=/soft/com/packages/intel/18/u3/mkl',
> This is on frog at MCS, but it will be the same on other machines as the macros configuration
> PETSC_HAVE_MKL_SPARSE_OPTIMIZE not defined
> PETSC_HAVE_MKL_SPARSE_SP2M defined
> does not seem to be supported.
> /nfs2/szampini/src/petsc/src/mat/impls/aij/seq/aijmkl/aijmkl.c(797): error: struct "<unnamed>" has no field "csrA"
>     csrA = a->csrA;
> Could you please take a look? Why is the mkl_sparse_sp2m package flagged as lookforbydefault in the configure scripts?
> Thanks
> Stefano
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20181203/bab64f3a/attachment.html>
