[petsc-dev] Implementing of a variable block size BILU preconditioner
Ali Reza Khaz'ali
arkhazali at cc.iut.ac.ir
Mon Dec 3 16:49:17 CST 2018
Ithink that the topic is more suited for PETSc-developers than its
users; therefore, I move it to the dev list.
Continuing the discussion on implementing a variable-block size BILU
preconditioner, would it be possible to change the block size parameter
(bs) on BAIJ format such that it can handle variable block sizes? (i.e.,
instead of it being a scalar, it can be an array). Although BILU does
not necessarily require rectangular blocks, I think, it leads to less
messy code.
Also, being a newbie on PETSc code, I do not understand some parts of
the code, especially distributed matrix storage and some of the
implemented numerical algorithms. Is there any reference that I can use
for this?
Ali Reza Khaz’ali
Assistant Professor of Petroleum Engineering,
Department of Chemical Engineering
Isfahan University of Technology
Isfahan, Iran
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20181204/5eea3f1a/attachment.html>
