[petsc-dev] No rule to make target 'mfem-build'
Hapla Vaclav
vaclav.hapla at erdw.ethz.ch
Sat Dec 1 13:22:15 CST 2018
... except that it somehow passes this MAKEFLAGS= to configure, resulting in the confusing message ...
1. 12. 2018 v 17:33, Stefano Zampini <stefano.zampini at gmail.com<mailto:stefano.zampini at gmail.com>>:
Make reconfigure is equivalent to rerun the configure script
Il giorno Sab 1 Dic 2018, 18:09 Hapla Vaclav <vaclav.hapla at erdw.ethz.ch<mailto:vaclav.hapla at erdw.ethz.ch>> ha scritto:
... but this is apparently not caused by your merge.
Is it just normal behavior of make reconfigure?
I didn't know about this, I always call the reconfigure script directly.
Vaclav
> 1. 12. 2018 v 16:04, Hapla Vaclav <vaclav.hapla at erdw.ethz.ch<mailto:vaclav.hapla at erdw.ethz.ch>>:
> Thanks, you're right.
> However,
> $ make reconfigure
> Configuring PETSc to compile on your system
> ***** WARNING: MAKEFLAGS (set to ) found in environment variables - ignoring
> use ./configure MAKEFLAGS=$MAKEFLAGS if you really want to use that value ****** ===============================================================================
> although I have no such variable set in my shell.
> Vaclav
>> 1. 12. 2018 v 15:36, Stefano Zampini <stefano.zampini at gmail.com<mailto:stefano.zampini at gmail.com>>:
>> I have added a new package that gets built after petsc. You have to run
>> make reconfigure
>> Il giorno Sab 1 Dic 2018, 16:52 Hapla Vaclav <vaclav.hapla at erdw.ethz.ch<mailto:vaclav.hapla at erdw.ethz.ch>> ha scritto:
>> Hi Stefano
>> After pulling latest master, I get the following at the end of make output:
>> make[1]: *** No rule to make target 'mfem-build', needed by 'all-gnumake-local'. Stop.
>> make[1]: Leaving directory '/scratch/petsc-dev-1'
>> Now to check if the libraries are working do:
>> make PETSC_DIR=/scratch/petsc-dev-1 PETSC_ARCH=arch-linux-gcc check
>> Do you think you could remove that line for non-mfem builds? I think it looks like an error for a user.
>> Vaclav
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20181201/fd042e03/attachment.html>
