[petsc-dev] No rule to make target 'mfem-build'
Stefano Zampini
stefano.zampini at gmail.com
Sat Dec 1 10:33:05 CST 2018
Make reconfigure is equivalent to rerun the configure script
Il giorno Sab 1 Dic 2018, 18:09 Hapla Vaclav <vaclav.hapla at erdw.ethz.ch> ha
scritto:
> ... but this is apparently not caused by your merge.
> Is it just normal behavior of make reconfigure?
> I didn't know about this, I always call the reconfigure script directly.
> Vaclav
> > 1. 12. 2018 v 16:04, Hapla Vaclav <vaclav.hapla at erdw.ethz.ch>:
> > Thanks, you're right.
> > However,
> > $ make reconfigure
> > Configuring PETSc to compile on your system
> > ***** WARNING: MAKEFLAGS (set to ) found in
> environment variables - ignoring
> > use ./configure MAKEFLAGS=$MAKEFLAGS if you
> really want to use that value ******
> > although I have no such variable set in my shell.
> > Vaclav
> >> 1. 12. 2018 v 15:36, Stefano Zampini <stefano.zampini at gmail.com>:
> >> I have added a new package that gets built after petsc. You have to run
> >> make reconfigure
> >> Il giorno Sab 1 Dic 2018, 16:52 Hapla Vaclav <vaclav.hapla at erdw.ethz.ch>
> ha scritto:
> >> Hi Stefano
> >> After pulling latest master, I get the following at the end of make
> output:
> >> make[1]: *** No rule to make target 'mfem-build', needed by
> 'all-gnumake-local'. Stop.
> >> make[1]: Leaving directory '/scratch/petsc-dev-1'
> >> Now to check if the libraries are working do:
> >> make PETSC_DIR=/scratch/petsc-dev-1 PETSC_ARCH=arch-linux-gcc check
> >> Do you think you could remove that line for non-mfem builds? I think it
> looks like an error for a user.
> >> Vaclav
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20181201/cf1b48b5/attachment.html>
