[petsc-dev] No rule to make target 'mfem-build'
Stefano Zampini stefano.zampini at gmail.com
Sat Dec 1 08:36:59 CST 2018
I have added a new package that gets built after petsc. You have to run
make reconfigure
Il giorno Sab 1 Dic 2018, 16:52 Hapla Vaclav <vaclav.hapla at erdw.ethz.ch> ha
scritto:
> Hi Stefano
> After pulling latest master, I get the following at the end of make output:
> make[1]: *** No rule to make target 'mfem-build', needed by
> 'all-gnumake-local'.  Stop.
> make[1]: Leaving directory '/scratch/petsc-dev-1'
> Now to check if the libraries are working do:
> make PETSC_DIR=/scratch/petsc-dev-1 PETSC_ARCH=arch-linux-gcc check
> Do you think you could remove that line for non-mfem builds? I think it
> looks like an error for a user.
> Vaclav
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20181201/a0d271fa/attachment.html>
