[petsc-dev] Gathering information: types of interpolations in PETSc and which ones are supported?
Matthew Knepley
knepley at gmail.com
Fri Aug 31 14:52:25 CDT 2018
On Fri, Aug 31, 2018 at 2:20 PM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> PETSc developers,
> There are a variety of "interpolation" modules in PETSc but the
> documentation is scattered (mostly missing). Could everyone who knows
> anything about the various modules provide a little information about which
> modes exist as interfaces and which have actual supporting code and
> expected usage? Anything duplicative?
> 1) nested DM to DM (mesh to mesh) of the same type of DM seems to be
> supported for DMDA and DMPLEX using DMCreateInterpolation(). But what is
> DMPlexComputeInterpolatorNested(DM, DM, Mat, void *), how is it different?
> (Note usr context is not used)
DMCreateInterpolation() says nothing about nesting, and in fact lets people
create arbitrary algebraic interpolation. For DMPlex, we support
both nested and non-nested MG (Patrick says there is a subtle bug in
non-nested), but my tests pass for this. The Nested case is obviously much
easier and has a fixed element matrix, whereas non-nested uses point
location.
> 2) non-nested DM to DM. DMPlexComputeInterpolatorGeneral(DM, DM, Mat, void
> *); (and what does "local portion" mean?) (also the usr context? is not
> used).
We can take out "local portion". That was me talking to myself.
> 3) DM to a set of points (mesh to points) with DMInterpolationInfo and
> the routines DMInterpolationEvaluate() etc. Is this fully implemented for
> DMPLEX, DMDA?
This relies on the DMLocatePoints(), which I think was implemented for
both, but if it isn't for DMDA, its trivial and we should do it.
> Parallel, does the user need to know which process the points are on or is
> that all figured out?
That is figured out. Actually, its most of the reason that this exists.
However, I wrote this a long time ago. It should go away in favor of
DMSwarm.
> 4) Points to a DM. Is this supported (should be?) by DMSWARM? In fact
> should 3) work with DMSWARM as the set of points and not have its own
> construct (DMInterpolationInfo)?
This is supported. However, what is currently in there is custom code Dave
wrote which only works for P1. We now have code
that does this for any element and in all dimensions. Its in a branch and
will get merged shortly (next week) since it passes all
tests. However, we need some more time to fully integrate it into the
interface currently in DMSwarm.
Another problem is that Dave has a different definition of points than the
plasma people. We need a nice way
to switch between these perspectives when doing interpolation, which is
what will take us a little time when we are integrating.
> 5) Points to points? (Done indirectly by interpolating to a DM then back
> to the other points)?
Yes, that is how I would do it.
> There is a routine DMPlexInterpolate() is this mis-named/confusing thing?
> Interpolate seems to mean something slight different here.
Yes. Unfortunately, the same word is used by topology people. I am willing
to change this since very few people use it, when they do its
only used once, and its completely different. It refers to figuring out the
edges and faces automatically in a mesh when you get only cells
and vertices. Better name?
Matt
> All of this explanation could go into the users manual (or FAQ for now).
> Thanks for any explanations,
> Barry
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180831/22f9356a/attachment.html>
