[petsc-dev] How to enforce private data/methods in PETSc?
    Jeff Hammond
    jeff.science at gmail.com
    Sat Aug 11 11:57:14 CDT 2018
On Sat, Aug 11, 2018 at 6:58 AM Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > On Sat, Aug 11, 2018 at 12:02 AM Junchao Zhang <jczhang at mcs.anl.gov>
> wrote:
> >> See this example, after multiple casts, the code directly accesses
> >> VecScatter_MPI_General's members, with an assumption that from->n is the
> >> total number of receive processors. When I separate intranode /
> internode
> >> communications, I have to maintain this assumption.
> >> This is a good example. VecScatter is a flagrant rule violator. It
> should
> > be rewritten with a proper API
> > to obtain this data.
> Also note that this code (which is in Mat) needs to
>   #include <petsc/private/vecimpl.h>
> which should ideally never happen.  That rule has been broken sometimes
> and it hasn't been a priority to create internal interfaces to fix these
> historical code smells (most VecScatter code dates from the mid-1990s),
> but we do try to avoid it in new code and refactor when making
> significant changes to old code.
> Note that in C++, you could
>   #define private public
>   #define protected public
> before including a header, and then could access any member.
https://stackoverflow.com/questions/27778908/define-private-to-public-in-c/27779038#27779038
You could also #define main to include an invocation of system() that would
erase your file system.
Jeff
> > And if one was going to rewrite it, my personal prejudice would be to try
> > and replace the communication
> > part with implementations of PetscSF. Right now SF can handle different
> > data types (Scatter cannot), but
> > Scatter has many more modes of communication, such as Alltoall, whereas
> SF
> > only has p2p and window.
> >    Matt
> >> 385: *PetscErrorCode <
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscErrorCode.html#PetscErrorCode>
> MatMatMultNumeric_MPIDense(Mat <
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/Mat.html#Mat>
> A,Mat <
> B,Mat <
> C)*386: {
> >> 389:   Mat_MPIAIJ             *aij = (Mat_MPIAIJ*) A->data;
> >> 393:   VecScatter <
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecScatter.html#VecScatter>
>            ctx   = aij->Mvctx;394:   VecScatter_MPI_General *from =
> (VecScatter_MPI_General*) ctx->fromdata;395:   VecScatter_MPI_General *to
>  = (VecScatter_MPI_General*) ctx->todata;
> >> 411:   PetscMalloc4 <
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscMalloc4.html#PetscMalloc4>(B->cmap->N*from->starts[from->n],&contents->rvalues,412:
>                      B->cmap->N*to->starts[to->n],&contents->svalues,413:
>                      from->n,&contents->rwaits,414:
>  to->n,&contents->swaits);
> >> --Junchao Zhang
> >> On Fri, Aug 10, 2018 at 10:33 PM Matthew Knepley <knepley at gmail.com>
> >> wrote:
> >>> On Fri, Aug 10, 2018 at 11:29 PM Junchao Zhang <jczhang at mcs.anl.gov>
> >>> wrote:
> >>>> It seems we do not have naming conventions for private members.
> >>> I am not sure I understand. There are no public members. For private
> >>> functions, we do have
> >>> a naming convention, but it is newly created, so many of the existing
> >>> functions break the rules.
> >>>    Matt
> >>>> --Junchao Zhang
> >>>> On Fri, Aug 10, 2018 at 9:43 PM Matthew Knepley <knepley at gmail.com>
> >>>> wrote:
> >>>>> On Fri, Aug 10, 2018 at 5:43 PM Junchao Zhang <jczhang at mcs.anl.gov>
> >>>>> wrote:
> >>>>>>  I met several bugs that remind me to raise this question. In PETSc,
> >>>>>> object of type A can arbitrarily access object of type B's data. But
> >>>>>> designer of B may later change the meaning of its data (and of
> course,
> >>>>>> update B's interfaces, which are usually local to few files). The
> designer
> >>>>>> may think the job is done, but actually it is not.  He/she has to
> grep the
> >>>>>> code to know where its data members are accessed (that is
> relatively easy
> >>>>>> to get) and what is the contract, for example, is an array assumed
> to be
> >>>>>> sorted (that is hard to know).  With C++, one can use private to
> minimize
> >>>>>> data exposure.
> >>>>> This just has to be coding discipline. People should not be accessing
> >>>>> private members.
> >>>>>    Matt
> >>>>>> --Junchao Zhang
> >>>>> What most experimenters take for granted before they begin their
> >>>>> experiments is infinitely more interesting than any results to which
> their
> >>>>> experiments lead.
> >>>>> -- Norbert Wiener
> >>>>> https://www.cse.buffalo.edu/~knepley/ <
> http://www.caam.rice.edu/~mk51/>
> their
> >>> experiments lead.
> >>> -- Norbert Wiener
> >>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/
> their
> > experiments lead.
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
Jeff Hammond
http://jeffhammond.github.io/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180811/c396081f/attachment.html>
