[petsc-dev] How to enforce private data/methods in PETSc?
Jed Brown
jed at jedbrown.org
Sat Aug 11 08:58:04 CDT 2018
Matthew Knepley <knepley at gmail.com> writes:
> On Sat, Aug 11, 2018 at 12:02 AM Junchao Zhang <jczhang at mcs.anl.gov> wrote:
>> See this example, after multiple casts, the code directly accesses
>> VecScatter_MPI_General's members, with an assumption that from->n is the
>> total number of receive processors. When I separate intranode / internode
>> communications, I have to maintain this assumption.
>> This is a good example. VecScatter is a flagrant rule violator. It should
> be rewritten with a proper API
> to obtain this data.
Also note that this code (which is in Mat) needs to
#include <petsc/private/vecimpl.h>
which should ideally never happen. That rule has been broken sometimes
and it hasn't been a priority to create internal interfaces to fix these
historical code smells (most VecScatter code dates from the mid-1990s),
but we do try to avoid it in new code and refactor when making
significant changes to old code.
Note that in C++, you could
#define private public
#define protected public
before including a header, and then could access any member.
> And if one was going to rewrite it, my personal prejudice would be to try
> and replace the communication
> part with implementations of PetscSF. Right now SF can handle different
> data types (Scatter cannot), but
> Scatter has many more modes of communication, such as Alltoall, whereas SF
> only has p2p and window.
> Matt
>> 385: *PetscErrorCode <http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscErrorCode.html#PetscErrorCode> MatMatMultNumeric_MPIDense(Mat <http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/Mat.html#Mat> A,Mat <http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/Mat.html#Mat> B,Mat <http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/Mat.html#Mat> C)*386: {
>> 389: Mat_MPIAIJ *aij = (Mat_MPIAIJ*) A->data;
>> 393: VecScatter <http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecScatter.html#VecScatter> ctx = aij->Mvctx;394: VecScatter_MPI_General *from = (VecScatter_MPI_General*) ctx->fromdata;395: VecScatter_MPI_General *to = (VecScatter_MPI_General*) ctx->todata;
>> 411: PetscMalloc4 <http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscMalloc4.html#PetscMalloc4>(B->cmap->N*from->starts[from->n],&contents->rvalues,412: B->cmap->N*to->starts[to->n],&contents->svalues,413: from->n,&contents->rwaits,414: to->n,&contents->swaits);
>> --Junchao Zhang
>> On Fri, Aug 10, 2018 at 10:33 PM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Fri, Aug 10, 2018 at 11:29 PM Junchao Zhang <jczhang at mcs.anl.gov>
>>> wrote:
>>>> It seems we do not have naming conventions for private members.
>>> I am not sure I understand. There are no public members. For private
>>> functions, we do have
>>> a naming convention, but it is newly created, so many of the existing
>>> functions break the rules.
>>> Matt
>>>> --Junchao Zhang
>>>> On Fri, Aug 10, 2018 at 9:43 PM Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Fri, Aug 10, 2018 at 5:43 PM Junchao Zhang <jczhang at mcs.anl.gov>
>>>>> wrote:
>>>>>> I met several bugs that remind me to raise this question. In PETSc,
>>>>>> object of type A can arbitrarily access object of type B's data. But
>>>>>> designer of B may later change the meaning of its data (and of course,
>>>>>> update B's interfaces, which are usually local to few files). The designer
>>>>>> may think the job is done, but actually it is not. He/she has to grep the
>>>>>> code to know where its data members are accessed (that is relatively easy
>>>>>> to get) and what is the contract, for example, is an array assumed to be
>>>>>> sorted (that is hard to know). With C++, one can use private to minimize
>>>>>> data exposure.
>>>>> This just has to be coding discipline. People should not be accessing
>>>>> private members.
>>>>> Matt
>>>>>> --Junchao Zhang
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
