[petsc-dev] Compiling error with Hypre-2.11.2
    Satish Balay
    balay at mcs.anl.gov
    Thu Aug  2 11:50:09 CDT 2018
https://bitbucket.org/petsc/petsc/commits/e6de09342ce9c4562cc062ff2c1bac4bd956bda0
It is compatible with Hypre-2.14. For Hypre-2.11 - you would have to revert the above change.
Satish
On Thu, 2 Aug 2018, Antonio Trande wrote:
> Hi all.
> Petsc-3.9.3 does not compile against Hypre-2.11.2:
> mpicc -c -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions
> -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches
>   -m64 -mtune=generic -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2
> -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4
> -grecord-gcc-switches   -m64 -mtune=generic -O3 -Wl,-z,now -fPIC
> -I/builddir/build/BUILD/petsc-3.9.3/buildopenmpi_dir/include
> -I/builddir/build/BUILD/petsc-3.9.3/buildopenmpi_dir/x86_64/include
> -I/usr/include/openmpi-x86_64 -I/usr/include/openmpi-x86_64/hypre
> -MMD -MP
> /builddir/build/BUILD/petsc-3.9.3/buildopenmpi_dir/src/mat/impls/composite/mcomposite.c
> -o x86_64/obj/mat/impls/composite/mcomposite.o
> /builddir/build/BUILD/petsc-3.9.3/buildopenmpi_dir/src/mat/impls/hypre/mhypre.c:
> In function 'hypre_array_destroy':
> /builddir/build/BUILD/petsc-3.9.3/buildopenmpi_dir/src/mat/impls/hypre/mhypre.c:1453:37:
> error: macro "hypre_TFree" passed 2 arguments, but takes just 1
>     hypre_TFree(ptr,HYPRE_MEMORY_HOST);
> /builddir/build/BUILD/petsc-3.9.3/buildopenmpi_dir/src/mat/impls/hypre/mhypre.c:1453:4:
> error: 'hypre_TFree' undeclared (first use in this function)
> note: each undeclared identifier is reported only once for each function
> it appears in
> gmake[2]: *** [x86_64/obj/mat/impls/hypre/mhypre.o] Error 1
> gmake[2]: *** Waiting for unfinished jobs....
> gmake[2]: Leaving directory
> `/builddir/build/BUILD/petsc-3.9.3/buildopenmpi_dir'
> Full build log:
> https://koji.fedoraproject.org/koji/getfile?taskID=28789567&volume=DEFAULT&name=build.log
> Dependencies list:
> https://kojipkgs.fedoraproject.org//work/tasks/9567/28789567/root.log
