[petsc-dev] Compiling error with Hypre-2.11.2
    Antonio Trande
    anto.trande at gmail.com
    Thu Aug  2 11:46:43 CDT 2018
Hi all.
Petsc-3.9.3 does not compile against Hypre-2.11.2:
mpicc -c -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions
-fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches
  -m64 -mtune=generic -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2
-fexceptions -fstack-protector-strong --param=ssp-buffer-size=4
-grecord-gcc-switches   -m64 -mtune=generic -O3 -Wl,-z,now -fPIC
-I/builddir/build/BUILD/petsc-3.9.3/buildopenmpi_dir/include
-I/builddir/build/BUILD/petsc-3.9.3/buildopenmpi_dir/x86_64/include
-I/usr/include/openmpi-x86_64 -I/usr/include/openmpi-x86_64/hypre
-MMD -MP
/builddir/build/BUILD/petsc-3.9.3/buildopenmpi_dir/src/mat/impls/composite/mcomposite.c
-o x86_64/obj/mat/impls/composite/mcomposite.o
/builddir/build/BUILD/petsc-3.9.3/buildopenmpi_dir/src/mat/impls/hypre/mhypre.c:
In function 'hypre_array_destroy':
/builddir/build/BUILD/petsc-3.9.3/buildopenmpi_dir/src/mat/impls/hypre/mhypre.c:1453:37:
error: macro "hypre_TFree" passed 2 arguments, but takes just 1
    hypre_TFree(ptr,HYPRE_MEMORY_HOST);
/builddir/build/BUILD/petsc-3.9.3/buildopenmpi_dir/src/mat/impls/hypre/mhypre.c:1453:4:
error: 'hypre_TFree' undeclared (first use in this function)
note: each undeclared identifier is reported only once for each function
it appears in
gmake[2]: *** [x86_64/obj/mat/impls/hypre/mhypre.o] Error 1
gmake[2]: *** Waiting for unfinished jobs....
gmake[2]: Leaving directory
`/builddir/build/BUILD/petsc-3.9.3/buildopenmpi_dir'
Full build log:
https://koji.fedoraproject.org/koji/getfile?taskID=28789567&volume=DEFAULT&name=build.log
Dependencies list:
https://kojipkgs.fedoraproject.org//work/tasks/9567/28789567/root.log
Antonio Trande
Fedora Project
mailto 'sagitter at fedoraproject dot org'
GPG key: 0x5E212EE1D35568BE
GPG key server: https://keys.fedoraproject.org/
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180802/240e19ad/attachment.sig>
