[petsc-dev] Install location for MPIUNI mpi.h
Satish Balay
balay at mcs.anl.gov
Wed Apr 25 14:21:14 CDT 2018
If we really have to change - I'm inclined towards Matt's prefered approach.
[issues with 'dirty builddir' is a separate problem - it comes up with
switching between replaceable packages [openmpi,mpich,mpiuni] - or
switching versions of the same package]
Satish
On Wed, 25 Apr 2018, Matthew Knepley wrote:
> On Wed, Apr 25, 2018 at 2:36 PM, Jed Brown <jed at jedbrown.org> wrote:
> > It is currently installed to include/petsc/mpiuni/mpi.h and petscsys.h
> > includes it as <mpi.h>, which means that users of MPIUNI need to put
> > -I/prefix/include/petsc/mpiuni in their command lines. Matt and I agree
> > that this is bad. We disagree on the solution.
> > He wants to install it to /prefix/include/mpi.h as though the user had
> > written --download-mpich. This would conflict if a user later installs
> > a real MPI to that location.
> The idea should be that "installing" means that everyone is using
> compatible things
> from that location. If you allow an MPIUNI PETSc to be installed to a
> location that
> also has another MPI, what does mpiexec in ./bin do? There is just as much
> potential
> for confusion as there is when putting an MPICH PETSc in a location with
> OpenMPI
> installed.
> Matt
> > I would rather that petscsys.h include <petsc/mpiuni/mpi.h> because it
> > can't be used without PETSc and nobody who ever wrote #include <mpi.h>
> > in their own code will be happy if they get MPIUNI.
