[petsc-dev] vector inner products
Munson, Todd
tmunson at mcs.anl.gov
Thu Apr 12 14:46:39 CDT 2018
My first choice is to remove the TaoGradientNorm() wrapper if there
is not anyone using it. It seems like a hack that would need more
significant thought to turn it into "not a hack".
Maybe Patrick F. can comment, as he is the one that added it.
FWIW, I think the user can already change the inner products by
writing their own using a VecShell.
Todd.
> On Apr 12, 2018, at 2:17 PM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> I don't know if we are ready for this dramatic change. I wouldn't do it until there was a clear need (not just potential future usage) that would be cumbersome to do without this generality. I am a little scared of this without demonstrated general need.
> I would start by having an abstract inner product object (which includes a norm function) that has the standard l2 implementation, then another implementation that is based on passing in a matrix, maybe one based on passing in a vector. Then each solver would have a XXXSetInnerProduct() while defaulting to l2.
> Barry
>> On Apr 12, 2018, at 12:21 PM, Munson, Todd <tmunson at mcs.anl.gov> wrote:
>> There is a bit of code in TAO that allows the user to change the norm to
>> a matrix norm. This was introduced to get some mesh independent
>> behavior in one example (tao/examples/tutorials/ex3.c). That
>> norm, however, does not propagate down into the KSP methods
>> and is only used for testing convergence of the nonlinear
>> problem.
>> A few questions then: Is similar functionality needed in SNES? Are
>> TAO and SNES even the right place for this functionality? Should
>> it belong to the Vector class so that you can change the inner
>> products and have all the KSP methods (hopefully) work
>> correctly?
>> Note: that this discussion brings us to the brink of supporting an
>> optimize-then-discretize approach. I am not convinced we should
>> go down that rabbit hole.
>> Thanks, Todd.
