[petsc-dev] vector inner products
Smith, Barry F.
bsmith at mcs.anl.gov
Thu Apr 12 14:17:52 CDT 2018
I don't know if we are ready for this dramatic change. I wouldn't do it until there was a clear need (not just potential future usage) that would be cumbersome to do without this generality. I am a little scared of this without demonstrated general need.
I would start by having an abstract inner product object (which includes a norm function) that has the standard l2 implementation, then another implementation that is based on passing in a matrix, maybe one based on passing in a vector. Then each solver would have a XXXSetInnerProduct() while defaulting to l2.
Barry
> On Apr 12, 2018, at 12:21 PM, Munson, Todd <tmunson at mcs.anl.gov> wrote:
> There is a bit of code in TAO that allows the user to change the norm to
> a matrix norm. This was introduced to get some mesh independent
> behavior in one example (tao/examples/tutorials/ex3.c). That
> norm, however, does not propagate down into the KSP methods
> and is only used for testing convergence of the nonlinear
> problem.
> A few questions then: Is similar functionality needed in SNES? Are
> TAO and SNES even the right place for this functionality? Should
> it belong to the Vector class so that you can change the inner
> products and have all the KSP methods (hopefully) work
> correctly?
> Note: that this discussion brings us to the brink of supporting an
> optimize-then-discretize approach. I am not convinced we should
> go down that rabbit hole.
> Thanks, Todd.
