[petsc-dev] getting on with the nested timers
Thu Apr 5 06:58:56 CDT 2018
On Thu, Apr 5, 2018 at 7:50 AM, Klaij, Christiaan <C.Klaij at marin.nl> wrote:
> ??? In my original email I mention that page and state that the
> command line option is working.
> Were you expecting me to understand from your reply that the
> option :ascii_xml somehow translates to
> PetscViewerPushFormat(viewer,"PETSC_VIEWER_ASCII_XML")?
Yes. The format for viewer input is
  -foo_view type:filename:format:mode
where any argument can be omitted so that it takes the default. The
defaults are
  type        - ascii
  filename - stdout
  format    - FORMAT_DEFAULT
  mode     - read
      Matt
> Chris
> *From:* Matthew Knepley <knepley at gmail.com>
> *Sent:* Thursday, April 05, 2018 1:35 PM
> *To:* Klaij, Christiaan
> *Cc:* Smith, Barry F.; petsc-dev at mcs.anl.gov; Koos Huijssen
> *Subject:* Re: [petsc-dev] getting on with the nested timers
> On Thu, Apr 5, 2018 at 7:31 AM, Klaij, Christiaan <C.Klaij at marin.nl>
> wrote:
>> Matt,
>> I guess you meant to send this link:
>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/
>> Viewer/PetscViewerPushFormat.html
> No, I meant to send the link I sent. In the section Options Database Keys,
> it gives you the format.
>   Matt
>> If so, it doesn't say anything on XML either. But after some
>> trial and error I found the format to
>> be "PETSC_VIEWER_ASCII_XML", so problem solved.
>> Summarizing the problem from a user perspective:
>> 1) The manual page of PetscLogView mentions PetscViewerASCIIOpen,
>> which mentions PetscViewerPushFormat, I should have figured that
>> out by myself, sorry.
>> 2) The manual page of PetscLogView mentions PetscLogNestedBegin,
>> which doesn't have a manual entry.
>> 3) The manual page of PetscViewerPushFormat doesn't mention the
>> format PETSC_VIEWER_ASCII_XML, although it is available.
>> Chris
>> dr. ir. Christiaan Klaij | Senior Researcher | Research & Development
>> MARIN | T +31 317 49 33 44 | C.Klaij at marin.nl | www.marin.nl
>> [image: LinkedIn] <https://www.linkedin.com/company/marin> [image:
>> YouTube] <http://www.youtube.com/marinmultimedia> [image: Twitter]
>> <https://twitter.com/MARIN_nieuws> [image: Facebook]
>> <https://www.facebook.com/marin.wageningen>
>> MARIN news: Comfort draft for semi-submersible yachts
>> <http://www.marin.nl/web/News/News-items/Comfort-draft-for-semisubmersible-yachts.htm>
>> *Sent:* Thursday, April 05, 2018 12:50 PM
>> On Thu, Apr 5, 2018 at 6:15 AM, Klaij, Christiaan <C.Klaij at marin.nl>
>> wrote:
>>> Barry,
>>> I'm still trying to use petsc's nested logging with our code. I
>>> have it working for 3.8.3 with the command line option, for
>>> example:
>>> mpirun -n 3 ./refresco -log_view :performance.xml:ascii_xml
>>> This gives the expected performance.xml file. How to get the same
>>> without command line options? So far I have:
>>> CALL PetscLogDefaultBegin(ierr)
>>> CALL PetscViewerASCIIOpen(MPI_COMM_WORLD,'performance.xml',viewer,ierr)
>>> CALL PetscLogView(viewer,ierr)
>>> which gives the regular log in the performance.xml file.
>>> I guess I should replace PetscLogDefaultBegin by
>>> PetscLogNestedBegin as stated in the manual page of PetscLogView.
>>> But there's no manual page for PetscLogNestedBegin and I didn't
>>> find anything like PetscViewerASCIIOpenXML either.
>> http://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/P
>> rofiling/PetscLogView.html
>> You need to push the ASCII_XML format before viewing.
>>   Thanks,
>>      Matt
>>> Chris
>>> MARIN | T +31 317 49 33 44 | mailto:C.Klaij at marin.nl |
>>> http://www.marin.nl
>>> MARIN news: http://www.marin.nl/web/News/News-items/Kom-zaterdag-10-nove
>>> mber-naar-de-open-dag-in-Wageningen.htm
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180405/373535ff/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180405/373535ff/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180405/373535ff/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180405/373535ff/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180405/373535ff/attachment-0007.png>
