[petsc-dev] getting on with the nested timers
Klaij, Christiaan
C.Klaij at marin.nl
Thu Apr 5 06:50:21 CDT 2018
??? In my original email I mention that page and state that the
command line option is working.
Were you expecting me to understand from your reply that the
option :ascii_xml somehow translates to
PetscViewerPushFormat(viewer,"PETSC_VIEWER_ASCII_XML")?
Chris
Sent: Thursday, April 05, 2018 1:35 PM
To: Klaij, Christiaan
Cc: Smith, Barry F.; petsc-dev at mcs.anl.gov; Koos Huijssen
Subject: Re: [petsc-dev] getting on with the nested timers
On Thu, Apr 5, 2018 at 7:31 AM, Klaij, Christiaan <C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>> wrote:
Matt,
I guess you meant to send this link:
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Viewer/PetscViewerPushFormat.html
No, I meant to send the link I sent. In the section Options Database Keys, it gives you the format.
Matt
If so, it doesn't say anything on XML either. But after some
trial and error I found the format to
be "PETSC_VIEWER_ASCII_XML", so problem solved.
Summarizing the problem from a user perspective:
1) The manual page of PetscLogView mentions PetscViewerASCIIOpen,
which mentions PetscViewerPushFormat, I should have figured that
out by myself, sorry.
2) The manual page of PetscLogView mentions PetscLogNestedBegin,
which doesn't have a manual entry.
3) The manual page of PetscViewerPushFormat doesn't mention the
format PETSC_VIEWER_ASCII_XML, although it is available.
Chris
dr. ir. Christiaan Klaij | Senior Researcher | Research & Development
MARIN | T +31 317 49 33 44 | C.Klaij at marin.nl<mailto:C.Klaij at marin.nl> | www.marin.nl<http://www.marin.nl>
[LinkedIn]<https://www.linkedin.com/company/marin> [YouTube] <http://www.youtube.com/marinmultimedia> [Twitter] <https://twitter.com/MARIN_nieuws> [Facebook] <https://www.facebook.com/marin.wageningen>
MARIN news: Comfort draft for semi-submersible yachts<http://www.marin.nl/web/News/News-items/Comfort-draft-for-semisubmersible-yachts.htm>
From: Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>>
Sent: Thursday, April 05, 2018 12:50 PM
Cc: Smith, Barry F.; petsc-dev at mcs.anl.gov<mailto:petsc-dev at mcs.anl.gov>; Koos Huijssen
On Thu, Apr 5, 2018 at 6:15 AM, Klaij, Christiaan <C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>> wrote:
Barry,
I'm still trying to use petsc's nested logging with our code. I
have it working for 3.8.3 with the command line option, for
example:
mpirun -n 3 ./refresco -log_view :performance.xml:ascii_xml
This gives the expected performance.xml file. How to get the same
without command line options? So far I have:
CALL PetscLogDefaultBegin(ierr)
CALL PetscViewerASCIIOpen(MPI_COMM_WORLD,'performance.xml',viewer,ierr)
CALL PetscLogView(viewer,ierr)
which gives the regular log in the performance.xml file.
I guess I should replace PetscLogDefaultBegin by
PetscLogNestedBegin as stated in the manual page of PetscLogView.
But there's no manual page for PetscLogNestedBegin and I didn't
find anything like PetscViewerASCIIOpenXML either.
http://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/Profiling/PetscLogView.html
You need to push the ASCII_XML format before viewing.
Matt
Chris
MARIN | T +31 317 49 33 44 | mailto:C.Klaij at marin.nl<mailto:C.Klaij at marin.nl> | http://www.marin.nl
MARIN news: http://www.marin.nl/web/News/News-items/Kom-zaterdag-10-november-naar-de-open-dag-in-Wageningen.htm
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.caam.rice.edu/~mk51/>
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180405/c97046f6/attachment.html>
Type: image/png
Desc: image003692.PNG
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180405/c97046f6/attachment.png>
Type: image/png
Desc: image8057bb.PNG
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180405/c97046f6/attachment-0001.png>
Type: image/png
Desc: image209c91.PNG
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180405/c97046f6/attachment-0002.png>
Type: image/png
Desc: image528f07.PNG
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180405/c97046f6/attachment-0003.png>
