[petsc-dev] FAS indentation
Tue Apr 3 18:24:23 CDT 2018
On Tue, Apr 3, 2018 at 7:16 PM, Dener, Alp <adener at anl.gov> wrote:
> Sure thing!
> Matt, just to give you a bit of detail, the Monitor() calls to ASCII
> viewers were changed to respect the tab levels for the parent objects
> instead of manually pushing and popping tabs on the printouts. The code
> also tries to preserve the existing tab levels of the viewer though — that
> is, we first save the existing tab level, then indent monitor printouts
> from the root (0 tab) using the object’s tab level, and then set the viewer
> back to whatever tab level it was at before the monitor is called. So in
> theory, it shouldn’t be changing the behavior of the viewer outside of the
> monitor. It is entirely possible I introduced a bug somewhere and that’s
> what I’m going to look for right now, but in the meantime please let me
> know if there’s a use-case or a test I can use for debugging as well.
The easiest thing to do is run all the SNES ex12 tests in next and look at
the indentation errors. I am now pushing fixes for all other errors, so
by the time you run there should be nothing else.
     Matt
> Thanks,
>> Alp Dener
> On April 3, 2018 at 6:11:12 PM, Smith, Barry F. (bsmith at mcs.anl.gov)
> wrote:
> Alp,
> Can you please take a look at this?
> Thanks
> Barry
> > On Apr 3, 2018, at 4:46 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > The recent indentation fix (I think) has broken the FAS solver
> indentation.
> > Matt
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180403/0d0d22a9/attachment.html>
