[petsc-dev] [issue1595] Issues of limited number of MPI communicators when having many instances of hypre boomerAMG with Moose
Smith, Barry F. bsmith at mcs.anl.gov
Tue Apr 3 17:35:03 CDT 2018
> On Apr 3, 2018, at 4:30 PM, Li, Ruipeng <li50 at llnl.gov> wrote:
> Hi, Fande,
> "For instance, if an application has multiple fields and each field will be solved by a HYPRE solver,  then we end up with  multiple hypre solves. The multiple hypre solves are not run simultaneously, instead, it will be run one-by-one. If we assign the same communicator to the multiple hypre solves, any potential tag conflict?"
> In this scenario, is just the solve phase of BoomerAMG one after another, or also the setup of AMG? Since BoomerAMG takes the communicator from the A matrix, if the entire hypre solve (setup + solve) is serial, there should be no conflicts.
    It would be mostly be
setup on first matrix solve on first matrix
setup on second matrix solve on second matrix
  Barry
> -Ruipeng
> Ruipeng Li
> Center for Applied Scientific Computing
> Lawrence Livermore National Laboratory
> P.O. Box 808, L-561
> Livermore, CA 94551
> phone - (925) 422-6037,  email - li50 at llnl.gov
> From: Kong, Fande <fande.kong at inl.gov>
> Sent: Tuesday, April 3, 2018 1:34 PM
> To: hypre-support
> Cc: Barry Smith; Derek Gaston; Li, Ruipeng; Osei-Kuffuor, Daniel; For users of the development version of PETSc; Schroder, Jacob B.; tzanio at llnl.gov; umyang at llnl.gov; Wang, Lu
> Subject: Re: [issue1595] Issues of limited number of MPI communicators when having many instances of hypre boomerAMG with Moose
> On Tue, Apr 3, 2018 at 2:12 PM, Rob Falgout hypre Tracker <hypre-support at llnl.gov<mailto:hypre-support at llnl.gov>> wrote:
> Rob Falgout <rfalgout at llnl.gov<mailto:rfalgout at llnl.gov>> added the comment:
> Hi Barry,
> Can you explain the scenario where multiple hypre solves would be working in parallel with the same communicator?  Thanks!
> Hi Rob,
> Fande,
> -Rob
> ____________________________________________
> hypre Issue Tracker <hypre-support at llnl.gov<mailto:hypre-support at llnl.gov>>
> <https://urldefense.proofpoint.com/v2/url?u=http-3A__cascb1.llnl.gov_hypre_issue1595&d=DwIFaQ&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB__aEkJFOKJFd00&r=DUUt3SRGI0_JgtNaS3udV68GRkgV4ts7XKfj2opmiCY&m=3KsQjTxI8eRWrSIJtB3o9NlBc4bEuuP4HxiT-BlMx3U&s=FjvfvXD21bX8LA2TAD-J6MWCJyMNm0aameRp_9nfLYs&e=>
