[petsc-dev] upcoming release and testing
Satish Balay
balay at mcs.anl.gov
Sun Apr 1 11:42:40 CDT 2018
On Sun, 1 Apr 2018, Satish Balay wrote:
> I'll try to send follow up emails on master brakages.
Blaise,
http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2018/03/31/examples_master_arch-c-exodus-dbg-builder_es.log
dm_impls_plex_tests-ex26 has bunch of memory leaks and diffs. I could track one of the memory leaks to f94b4a023f1c697a53e49ac853a9031583ab9737 - but don't know what the trigger is - or how to fix it.
not ok diff-dm_impls_plex_tests-ex26_6
# 969a970,2569
# > [ 0]16 bytes PetscSFBasicGetPack() line 806 in /sandbox/petsc/petsc.master-3/src/vec/is/sf/impls/basic/sfbasic.c
# > [0] PetscMallocA() line 806 in /sandbox/petsc/petsc.master-3/src/sys/memory/mal.c
# > [0] PetscSFBasicGetPack() line 778 in /sandbox/petsc/petsc.master-3/src/vec/is/sf/impls/basic/sfbasic.c
# > [0] PetscSFBcastBegin_Basic() line 923 in /sandbox/petsc/petsc.master-3/src/vec/is/sf/impls/basic/sfbasic.c
# > [0] PetscSFBcastBegin() line 1045 in /sandbox/petsc/petsc.master-3/src/vec/is/sf/interface/sf.c
# > [0] DMPlexGlobalToNaturalBegin() line 183 in /sandbox/petsc/petsc.master-3/src/dm/impls/plex/plexnatural.c
# > [0] VecViewPlex_ExodusII_Zonal_Internal() line 678 in /sandbox/petsc/petsc.master-3/src/dm/impls/plex/plexexodusii.c
And there are diffs which should be checked..
not ok diff-dm_impls_plex_tests-ex26_7
# 536c536
# < Cell Sets: 2 strata with value/size (3 (9), 5 (9))
# > Cell Sets: 2 strata with value/size (1 (9), 2 (9))
# 537a538,2137
not ok diff-dm_impls_plex_tests-ex26_10
# 536c536
# 537a538,2137
<snip>
# < 0-cells: 28 36
# < 1-cells: 58 67
# > 0-cells: 34 32
# > 1-cells: 64 63
# 734,735c734,2335
# < Cell Sets: 3 strata with value/size (2 (1), 3 (28), 5 (3))
# < depth: 3 strata with value/size (0 (28), 1 (58), 2 (32))
# > Cell Sets: 3 strata with value/size (1 (9), 2 (18), 3 (5))
# > depth: 3 strata with value/size (0 (34), 1 (64), 2 (32))
etc..
thanks,
Satish
