[petsc-dev] PetscSF in Fortran
Adrian Croucher
a.croucher at auckland.ac.nz
Wed Sep 27 23:12:48 CDT 2017
hi
On 28/09/17 15:34, Adrian Croucher wrote:
> So I think I will need to use PetscSFSetGraph() after all, so I can
> increase the number of roots, update the leaf point indices, and also
> update the remote root index for each leaf (presumably I can use the
> original SF and PetscSFBcastBegin/ PetscSFBcastEnd to do that).
> If you agree, then I will need working Fortran interfaces to the
> PetscSFGetGraph/ PetscSFSetGraph functions, which are missing at
> present. Are you able to add those easily?
It looks like the Fortran interfaces for PetscSFBcastBegin/
PetscSFBcastEnd are missing as well. I would need those to make this work.
- Adrian
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 4611
