[petsc-dev] why am I getting this message?
    Satish Balay
    balay at mcs.anl.gov
    Wed Sep 27 10:04:09 CDT 2017
On Wed, 27 Sep 2017, Mark Adams wrote:
> On Wed, Sep 27, 2017 at 9:00 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > What url do you have for origin? Send output from:
> > git config --local -l
> 07:53 cori01 maint= ~/petsc_install/petsc$ git config --local -l
> core.repositoryformatversion=0
> core.filemode=true
> core.bare=false
> core.logallrefupdates=true
> remote.origin.url=https://madams@bitbucket.org/petsc/petsc.git
> remote.origin.fetch=+refs/heads/*:refs/remotes/origin/*
> branch.master.remote=origin
> branch.master.merge=refs/heads/master
> branch.mark/snes-ex56c.remote=origin
> branch.mark/snes-ex56c.merge=refs/heads/mark/snes-ex56c
> branch.maint.remote=origin
> branch.maint.merge=refs/heads/maint
> branch.hzhang/fix-nonscalable-ctable-use.remote=origin
> branch.hzhang/fix-nonscalable-ctable-use.merge=refs/heads/hzhang/fix-nonscalable-ctable-use
> > And do you have to list 'origin' in pull? [I guess you need to do that
> > if you have multiple remotes?]
> I don't have multiple remotes
> > And what do you have for:
> > git fetch origin
> > git describe origin/maint
> > git describe maint
> 07:54 cori01 maint= ~/petsc_install/petsc$ git fetch origin
> 07:55 cori01 maint= ~/petsc_install/petsc$ git describe origin/maint
> v3.8
This should be 'git describe maint'
Satish
> v3.8
> > Satish
> > > I just pulled maint but still get a message that I am out of date:
> > > 1072  git pull origin
> > >  1073  h
> > > 05:12 cori01 maint= ~/petsc_install/petsc$ ../arch-cori-knl-opt-intel.py
> > > PETSC_DIR=$PWD
> > > The version of PETSc you are using is out-of-date, we recommend updating
> > to
> > > the new release
> > >  Available Version: 3.8   Installed Version: 3.7.6
> > > http://www.mcs.anl.gov/petsc/download/index.html
> > >              Configuring PETSc to compile on your system
