[petsc-dev] why am I getting this message?
    Mark Adams
    mfadams at lbl.gov
    Wed Sep 27 09:55:51 CDT 2017
On Wed, Sep 27, 2017 at 9:00 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> What url do you have for origin? Send output from:
> git config --local -l
07:53 cori01 maint= ~/petsc_install/petsc$ git config --local -l
core.repositoryformatversion=0
core.filemode=true
core.bare=false
core.logallrefupdates=true
remote.origin.url=https://madams@bitbucket.org/petsc/petsc.git
remote.origin.fetch=+refs/heads/*:refs/remotes/origin/*
branch.master.remote=origin
branch.master.merge=refs/heads/master
branch.mark/snes-ex56c.remote=origin
branch.mark/snes-ex56c.merge=refs/heads/mark/snes-ex56c
branch.maint.remote=origin
branch.maint.merge=refs/heads/maint
branch.hzhang/fix-nonscalable-ctable-use.remote=origin
branch.hzhang/fix-nonscalable-ctable-use.merge=refs/heads/hzhang/fix-nonscalable-ctable-use
> And do you have to list 'origin' in pull? [I guess you need to do that
> if you have multiple remotes?]
I don't have multiple remotes
> And what do you have for:
> git fetch origin
> git describe origin/maint
> git describe maint
07:54 cori01 maint= ~/petsc_install/petsc$ git fetch origin
07:55 cori01 maint= ~/petsc_install/petsc$ git describe origin/maint
v3.8
v3.8
> Satish
> On Wed, 27 Sep 2017, Mark Adams wrote:
> > I just pulled maint but still get a message that I am out of date:
> > 1072  git pull origin
> >  1073  h
> > 05:12 cori01 maint= ~/petsc_install/petsc$ ../arch-cori-knl-opt-intel.py
> > PETSC_DIR=$PWD
> > The version of PETSc you are using is out-of-date, we recommend updating
> to
> > the new release
> >  Available Version: 3.8   Installed Version: 3.7.6
> > http://www.mcs.anl.gov/petsc/download/index.html
> >              Configuring PETSc to compile on your system
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170927/ecc42f95/attachment.html>
