[petsc-dev] git repo branches housekeeping
Satish Balay
balay at mcs.anl.gov
Mon Apr 25 12:01:17 CDT 2016
ref: http://lists.mcs.anl.gov/pipermail/petsc-dev/2015-June/017808.html
I've deleted all deveopment branches that are already merged into
maint (v3.7) from https://bitbucket.org/petsc/petsc
However if you wish to remove these branches from your clone - it has
to be done manually (in each clone).
To get this list of branches to delete - you can do:
git branch --merged v3.7 |egrep -v " (maint|master|next)" > branches_to_delete
After *verifying* the list is correct - and ok to delete - they can be deleted with:
git branch -d `cat branches_to_delete`
And to sync the [deleted] remove branch list info - you can do:
git fetch -p
For more housekeeping - look at the remaining local and remote
branches and figure-out what to do. [perhaps some of them are
intermediate branches during rebase - or abandoned features that
should be deleted]. For my branches - I would do:
git branch
git branch -r |grep balay
Satish
reference for self:
$ git branch -r --merged v3.7 |egrep -v origin/\(maint\|master\|next\) |sed -e s%origin/%:% > remote_branches_to_delete
$ git push -u origin `cat remote_branches_to_delete`
To git at bitbucket.org:petsc/petsc.git
- [deleted] Fande-Kong/moved-partitioning-to-pcgasmsetup
- [deleted] balay-to-maint-fix-vs2015-vsnprintf
- [deleted] balay/add-KSPComputeRitz-patch
- [deleted] balay/add-clang-sa-build
- [deleted] balay/add-fortran-DMRemoveLabel
- [deleted] balay/configure-pkg-git-autoupdate
- [deleted] balay/el-parmetis-check
- [deleted] balay/el_AxpyInterface_removal
- [deleted] balay/fix-externalpackage-build-shared
- [deleted] balay/fix-fortran-unused_variables
- [deleted] balay/fix-sowing-valgrind
- [deleted] balay/fix-streams-npmax
- [deleted] balay/fix-win-isnan
- [deleted] balay/ftn-command_argument
- [deleted] balay/git-externalpackage-update
- [deleted] balay/improve-odpes
- [deleted] balay/rm-tree
- [deleted] balay/superlu_dist-4.3
- [deleted] balay/superlu_dist-4.3-p1
- [deleted] balay/to-maint-add-mpiuni_mpi_in_place
- [deleted] balay/to-maint-add-urlretrieve-timeout
- [deleted] balay/to-maint-fix-fortran-fflag-order
- [deleted] balay/to-maint-fix-gfortran51-warnings
- [deleted] balay/to-maint-fix-win64-long
- [deleted] balay/to-maint-metis-parmetis-nocxx
- [deleted] balay/to-maint-migrate-builds
- [deleted] balay/to-maint/update-superlu_dist-4.1
- [deleted] balay/update-elemental-0.86-pre
- [deleted] balay/update-gmake-check
- [deleted] balay/update-gnumake-41
- [deleted] balay/update-metis-xcode-fix-to-maint
- [deleted] balay/update-mpich-3.2
- [deleted] balay/update-sowing-svn
- [deleted] balay/update-superlu_dist_mar-16-294e2d0
- [deleted] barry-allow-vecset-nan-3.6
- [deleted] barry/Sylvain-gmres-symmetric
- [deleted] barry/add-concurrencykit
- [deleted] barry/add-dmdavecgetarrayreadf90/maint
- [deleted] barry/add-dmshellcreaterestriction
- [deleted] barry/add-mpiu_allreduce
- [deleted] barry/add-pcfieldsplit-logevent
- [deleted] barry/add-pcreset-hypre
- [deleted] barry/add-pcreset-hypre-for-master
- [deleted] barry/all-petscoptionssetvalue-beforepetscinitialize
- [deleted] barry/always-mark-floats
- [deleted] barry/better-matsetoption-error
- [deleted] barry/check-for-PetscInt-overflow
- [deleted] barry/check-nullspace-properties
- [deleted] barry/cleanup-pcsetupcalled
- [deleted] barry/cleanup-petscsys
- [deleted] barry/download-mstk
- [deleted] barry/download-pflowtran
- [deleted] barry/downloads
- [deleted] barry/error-on-extern-c-of-petscincludes
- [deleted] barry/feature-force-setting-exactfinaltime
- [deleted] barry/feature-linesearch-monitor
- [deleted] barry/feature-ts-monitor-binary
- [deleted] barry/fix-dmnetworkcomponentalignment
- [deleted] barry/fix-log-summary-format
- [deleted] barry/fix-matgetlocalsubmatrix
- [deleted] barry/fix-matheaderreplace
- [deleted] barry/fix-matseqaijgetarrayf90
- [deleted] barry/fix-mg-coarse-ksp-defaults
- [deleted] barry/fix-mg-coarse-redundant
- [deleted] barry/fix-mpiuni
- [deleted] barry/fix-mumps-destroy
- [deleted] barry/fix-nonew-notcollective/maint
- [deleted] barry/fix-petscviewer-attempt-2
- [deleted] barry/fix-private-functions
- [deleted] barry/fix-stageevent-idtypes
- [deleted] barry/fix-ts-matshift-error
- [deleted] barry/fix-win-e-00
- [deleted] barry/fix-xsdktrilinos
- [deleted] barry/fixes-for-release-1
- [deleted] barry/improve-git-download
- [deleted] barry/improve-minres
- [deleted] barry/improve-opt-handling
- [deleted] barry/improve-ts-monitor-interpolation
- [deleted] barry/list-downloads
- [deleted] barry/maint/fix-snessetupdate-fortran
- [deleted] barry/maint/mv-matnullspace-to-mat
- [deleted] barry/make-nonstatic-petscviewerflowcontrol
- [deleted] barry/master/fix-cuda-extern-c
- [deleted] barry/monitor-fromoptions
- [deleted] barry/not-single-precision
- [deleted] barry/optimize-xolotl
- [deleted] barry/petscoptions-object
- [deleted] barry/remove-matmffdaddnullspace/master
- [deleted] barry/remove-pc-nonzero-guess
- [deleted] barry/remove-pcsetup-mg-changeofpreonly/master
- [deleted] barry/remove-unneed-tao-tolerances
- [deleted] barry/shell-update-vector-states
- [deleted] barry/simplify-test-jobs
- [deleted] barry/update-hypre
- [deleted] barry/update-monitors
- [deleted] barry/update-petscmemoryshowusage
- [deleted] barry/update-superlu
- [deleted] barry/update-superlu_dist
- [deleted] barry/update-superlu_dist-again
- [deleted] barry/various-fixes
- [deleted] barry/xml-nested-logging
- [deleted] dalcinl/ts-2nd-order-systems
- [deleted] dalcinl/tsbdf
- [deleted] dmay/PetscSubcommDestroy-manpage
- [deleted] emil/doc-add-error-control
- [deleted] emil/fix-arkimex-diverged-reason
- [deleted] emil/fix-manual-typos-in-ts
- [deleted] emil/fix-ts-euler-generate-error-if-non-rhsfunction
- [deleted] emil/to-maint-fix-euler-interpolation
- [deleted] emil/to-maint-fix-ts-reporting-nonembedded
- [deleted] hongzh/add-checkpointing-support-for-adaptive-ts
- [deleted] hongzh/add-ts-trajectory-statistics
- [deleted] hongzh/checkpointing
- [deleted] hongzh/checkpointing-update
- [deleted] hongzh/fix-bug-for-cost-integral
- [deleted] hongzh/update-revolve
- [deleted] hongzh/update-ts-trajectory
- [deleted] hzhang/dmnetwork-spJacobian
- [deleted] hzhang/dmnetwork-spJacobian1
- [deleted] hzhang/dmnetwork-spJacobian2
- [deleted] hzhang/dmnetworkmonitor
- [deleted] hzhang/fix-pcredundant
- [deleted] hzhang/fix-ptapfill
- [deleted] hzhang/fix-superlu_dist
- [deleted] hzhang/inode-erroriffpe
- [deleted] hzhang/matconvert-den2el
- [deleted] hzhang/matgetsubmat_sbaij1
- [deleted] hzhang/matmatmult_crmax
- [deleted] hzhang/matmatmult_dense
- [deleted] hzhang/matpackage-erroriffpe
- [deleted] hzhang/matpackage-type
- [deleted] hzhang/mattransmatmult_dense
- [deleted] hzhang/mumps-getseterrorflg
- [deleted] hzhang/opt-ptap
- [deleted] hzhang/superlu-5.1
- [deleted] hzhang/superlu_dist-4.3-ex17
- [deleted] hzhang/update-networkex
- [deleted] hzhang/update-networkex-header
- [deleted] jed/dmdarestoreelements-strict
- [deleted] jed/fix-cuda-deps
- [deleted] jed/fix-ksp-norm-none
- [deleted] jed/fix-ml-visibility
- [deleted] jed/mat-assembly-perf
- [deleted] jed/process-options-handler
- [deleted] jed/workaround-mpich-naughty-ibarrier
- [deleted] jose/veccuda-complex
- [deleted] karlrupp/feature-ViennaCL-1.7.x
- [deleted] karlrupp/fix-matrixmarket-viewer
- [deleted] karlrupp/fix-petscinitialize-cuda
- [deleted] karpeev/fix-pcgasm-reuse
- [deleted] karpeev/fix-snes-test-docs
- [deleted] karpeev/maint-fix-gnupackage-ldflags
- [deleted] knepley/dm-fix-header-docs
- [deleted] knepley/doc-snes-ex1
- [deleted] knepley/feature-dmda-add-accessors
- [deleted] knepley/feature-drand48-portable
- [deleted] knepley/feature-ds-copy
- [deleted] knepley/feature-ex5-mms
- [deleted] knepley/feature-ex5-mms-params
- [deleted] knepley/feature-label-empty-stratum
- [deleted] knepley/feature-mpfr
- [deleted] knepley/feature-patrick-control-problem
- [deleted] knepley/feature-plex-add-time
- [deleted] knepley/feature-plex-handle-func-failure
- [deleted] knepley/feature-plex-jacp
- [deleted] knepley/feature-plex-ordering-group
- [deleted] knepley/feature-plex-point-location
- [deleted] knepley/feature-snes-deflation
- [deleted] knepley/feature-snes-setfunctionnorm
- [deleted] knepley/fix-configure-HOME
- [deleted] knepley/fix-configure-compiler-log
- [deleted] knepley/fix-configure-dirs
- [deleted] knepley/fix-configure-logging
- [deleted] knepley/fix-configure-ml
- [deleted] knepley/fix-configure-relative-installdir
- [deleted] knepley/fix-configure-saving
- [deleted] knepley/fix-dm-clone-coord-section
- [deleted] knepley/fix-dm-clone-coordinates
- [deleted] knepley/fix-dt-tanhsinh
- [deleted] knepley/fix-error-messages
- [deleted] knepley/fix-ex5-coords-empty
- [deleted] knepley/fix-ex5-patchwise
- [deleted] knepley/fix-examples-plex
- [deleted] knepley/fix-is-fortran
- [deleted] knepley/fix-msm-opt
- [deleted] knepley/fix-pc-composite-dm
- [deleted] knepley/fix-pc-msm
- [deleted] knepley/fix-plex-blocksize
- [deleted] knepley/fix-plex-c89
- [deleted] knepley/fix-plex-create-fortran
- [deleted] knepley/fix-plex-distribute-label
- [deleted] knepley/fix-plex-e12-3d
- [deleted] knepley/fix-plex-ex1f90
- [deleted] knepley/fix-plex-examples
- [deleted] knepley/fix-plex-general-interp
- [deleted] knepley/fix-plex-hdf5-label
- [deleted] knepley/fix-plex-l2diff
- [deleted] knepley/fix-plex-natural-mem
- [deleted] knepley/fix-plex-point-location
- [deleted] knepley/fix-plex-pragmatic-marking
- [deleted] knepley/fix-plex-regression
- [deleted] knepley/fix-plex-test-partitions
- [deleted] knepley/fix-quadrature-test
- [deleted] knepley/fix-seterrq-doc
- [deleted] knepley/fix-snes-ex5-mms
- [deleted] knepley/fix-snesqn-fortran
- [deleted] knepley/fix-solkx
- [deleted] knepley/plex-filter
- [deleted] knepley/remove-pbgl
- [deleted] knepley/snes-ex5-mms
- [deleted] knepley/test-asm-empty-subdomain
- [deleted] mark/eigen-rand
- [deleted] mark/gamg-crs
- [deleted] mark/gamg-rand
- [deleted] mesgarnejad/feature-plex-globaltonatural
- [deleted] mlange/fix-plex-fluent-reader
- [deleted] mlange/fix-plex-multi-level-overlap
- [deleted] pefarrell/tao-set-riesz-map
- [deleted] pr263/PierreBdR/ts-domain-error-in-stage/master
- [deleted] pr330/knepley/dmshell-set-create-subdm/master
- [deleted] pr332/master/Fande-Kong/mat-increaseoverlap-scalable
- [deleted] pr345/anriseth/anriseth/ngmres-reset-xm-increase/master
- [deleted] pr349/mapdes/extend_hypre_boomeramg_interface/master
- [deleted] pr352/dmay/pctelescope/master
- [deleted] pr353/dmeiser/fix-ex2_bjacobi-update/master
- [deleted] pr353/dmeiser/fix-ex2_bjacobi/master
- [deleted] pr358/buptphyphy/addmatcreatenormalhermitian/master
- [deleted] pr361/master/Fande-Kong/pcgasm-increaseoverlap
- [deleted] pr369/Fande-Kong/fixed-comment-space/master
- [deleted] pr372/vijaysm/vijaysm/moab_ts_examples_fix/master
- [deleted] pr380/semihozmen/semihozmen/ksp-eigen-comp-bugfix/master
- [deleted] pr384/Fande-Kong/fix-pcgasm-reuse/master
- [deleted] pr388/mapdes/fix-petscsf-create-section-sf/master
- [deleted] pr391/zianekhodja/lilia/tsirm/master
- [deleted] pr394/stevengcj/blassuffix/master
- [deleted] pr395/dmeiser/fix-veccuspgetarraywrite/master
- [deleted] pr401/tferma/virs-pcfieldsplit-fix/master
- [deleted] pr403/pascgeopc/psanan/ksp-pipe-flex/master
- [deleted] pr404/tferma/virs-divergedlinearsolve-fix-rebase/master
- [deleted] pr408/psanan/psanan/pc-bddc-view/master
- [deleted] pr412/psanan/psanan/ksp-cg-separate-singlereduction/master
- [deleted] pr413/scools/siegfriedcools/pipecgrr/master
- [deleted] pr417/adam_qc/fix-tao-ls-view-typo/master
- [deleted] pr421/alex/feature-veccuda
- [deleted] pr426/dmay/dmay/pctelescope-mods/master
- [deleted] pr428/bug-fixes-for-viennaclseqaij
- [deleted] psanan/benchmarks-cleanup
- [deleted] psanan/ksp-fgmres-reduce-alloc
- [deleted] sanderarens/fix-plex-neumann-bc
- [deleted] sarich/check-fcflags-fflags
- [deleted] sarich/feature-tao-pounders-add-correlations
- [deleted] sarich/fix-tao-man-objgrad
- [deleted] sarich/fix-vec-stepbound
- [deleted] sarich/fix-xsdk-packages
- [deleted] sarich/jenkins
- [deleted] shri/add-tsevent-to-powergrid-examples
- [deleted] stefano_zampini/enable-matcreatevecs-without-preallocation
- [deleted] stefano_zampini/feature-fetidp-classes
- [deleted] stefano_zampini/feature-pardiso-schur
- [deleted] stefano_zampini/feature-ptap-seqdense
- [deleted] stefano_zampini/feature-zerorowscolumns-seqdense
- [deleted] stefano_zampini/fix-for-release
- [deleted] stefano_zampini/fix-static-analyzer
- [deleted] stefano_zampini/matis-feature-localtoglobalmap-handling
- [deleted] stefano_zampini/matis-fix-create
- [deleted] stefano_zampini/somefixes-matdense-lda
- [deleted] tisaac/buildCheck-ignore-vc-moaning
- [deleted] tisaac/buildsystem-fix-pic
- [deleted] tisaac/dm-label-promote
- [deleted] tisaac/dm-locate-points-sf
- [deleted] tisaac/dmforest
- [deleted] tisaac/dmp4est-feature-injection
- [deleted] tisaac/dmplex-stable-tet-refinement
- [deleted] tisaac/dt-fix-geom-punning
- [deleted] tisaac/fix-static-analysis-warnings
- [deleted] tisaac/plex-feature-tree-fv
- [deleted] tisaac/plex-fix-ex3-const
- [deleted] tisaac/plex-fix-ex3-failure-message
- [deleted] tisaac/plex-fix-single-prec
- [deleted] tisaac/sf-fix-multi-sf-leaves
- [deleted] tomklotz/feature-tanh-sinh-quadrature
