[petsc-dev] Building local man pages
Tue Sep 19 16:46:17 CDT 2017
Pushed fixes now (to master). Can you retry?
Satish
On Tue, 19 Sep 2017, Stefano Zampini wrote:
> Maybe this has been answered before, but here it is. When trying to build
> HTML pages with
> $ make alldoc LOC=$PETSC_DIR
> With the latest master, I get this strange warning
> Could not open output file
> /home/szampini/src/petsc/docs/manualpages/DM/MLoad_Moab*/.html
> Reason: No such file or directory
> and then I get a latex error when compiling the manual
> cd src/docs/tex/manual; /usr/bin/gmake  --no-print-directory manual.pdf
> LOC=/home/szampini/src/petsc
> /usr/bin/pdflatex -halt-on-error manual1  > /dev/null 2>&1
> makefile:30: recipe for target 'manual.pdf' failed
> gmake[1]: *** [manual.pdf] Error 1
> makefile:340: recipe for target 'alldoc1' failed
> make: [alldoc1] Error 2 (ignored)
> cd src/docs/tex/manual; /usr/bin/gmake  --no-print-directory developers.pdf
> /usr/bin/pdflatex developerstmp.tex
> This is pdfTeX, Version 3.14159265-2.6-1.40.17 (TeX Live 2016) (preloaded
> format=pdflatex)
>  restricted \write18 enabled.
> entering extended mode
> (./developerstmp.tex
> LaTeX2e <2016/03/31>
> Babel <3.9r> and hyphenation patterns for 3 language(s) loaded.
> ! LaTeX Error: Missing \begin{document}.
> See the LaTeX manual or LaTeX Companion for explanation.
> Type  H <return>  for immediate help.
> l.1 B
>      ad line in /home/szampini/src/petsc/docs/manualpages/htmlmap
> man:+Compu...
> Should I run reconfigure?
