[petsc-dev] Building local man pages
Stefano Zampini
stefano.zampini at gmail.com
Tue Sep 19 14:55:33 CDT 2017
Maybe this has been answered before, but here it is. When trying to build
HTML pages with
$ make alldoc LOC=$PETSC_DIR
With the latest master, I get this strange warning
Could not open output file
/home/szampini/src/petsc/docs/manualpages/DM/MLoad_Moab*/.html
Reason: No such file or directory
and then I get a latex error when compiling the manual
cd src/docs/tex/manual; /usr/bin/gmake --no-print-directory manual.pdf
LOC=/home/szampini/src/petsc
/usr/bin/pdflatex -halt-on-error manual1 > /dev/null 2>&1
makefile:30: recipe for target 'manual.pdf' failed
gmake[1]: *** [manual.pdf] Error 1
makefile:340: recipe for target 'alldoc1' failed
make: [alldoc1] Error 2 (ignored)
cd src/docs/tex/manual; /usr/bin/gmake --no-print-directory developers.pdf
/usr/bin/pdflatex developerstmp.tex
This is pdfTeX, Version 3.14159265-2.6-1.40.17 (TeX Live 2016) (preloaded
format=pdflatex)
restricted \write18 enabled.
entering extended mode
(./developerstmp.tex
LaTeX2e <2016/03/31>
Babel <3.9r> and hyphenation patterns for 3 language(s) loaded.
! LaTeX Error: Missing \begin{document}.
See the LaTeX manual or LaTeX Companion for explanation.
Type H <return> for immediate help.
l.1 B
ad line in /home/szampini/src/petsc/docs/manualpages/htmlmap
man:+Compu...
Should I run reconfigure?
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170919/07c92084/attachment.html>
