[petsc-dev] ParMETIS change
Eric Chamberland Eric.Chamberland at giref.ulaval.ca
Wed Sep 13 09:39:37 CDT 2017
No "big" probleme here... just curious... I changed our code to use
real_t and everything is fine now.  Just wanted to understand the
reasons why it changed!
Thanks a lot!
Eric
On 13/09/17 10:07 AM, Balay, Satish wrote:
> What errors do you get? The primary code change was to use real_t
> instead of PetscReal in calls to parmetis.
> The change was done to make parmetis built by petsc be same as default
> parmetis that others/distros might build.
> And this enables consistent usage from quad build of petsc.
> I can add –download-metis-double or similar option to configure – if useful.
> Satish
> *From: *Eric Chamberland <mailto:Eric.Chamberland at giref.ulaval.ca>
> *Sent: *Wednesday, September 13, 2017 8:41 AM
> *To: *petsc-dev <mailto:petsc-dev at mcs.anl.gov>
> *Subject: *[petsc-dev] ParMETIS change
> Hi,
> having trouble to compile our code with PETSc-master new defaults
> options for PARMEtis.
> Parmetis was using double precision before...
> By curiosity, is there a big performance gain to use float?
> Thanks,
> Eric
