[petsc-dev] How can we improve log_view about objects created and destroyed?
Thu Sep 7 16:26:21 CDT 2017
  Fixed in barry/fix-log_view (except for the one missing viewer object). In next for testing. Can you run your bad code with this branch and see if the problem is truly gone.
   Thanks
  Barry
> On Sep 1, 2017, at 2:42 AM, Stefano Zampini <stefano.zampini at gmail.com> wrote:
> As it is now, if you create any object and use PetscObjectRegisterDestroy, the output from log_view may be misleading, as it will show something like this
> Memory usage is given in bytes:
> Object Type          Creations   Destructions     Memory  Descendants' Mem.
> Reports information only for process 0.
> --- Event Stage 0: Main Stage
>            Index Set   237            237       310852     0.
>    IS L to G Mapping    53             35        75260     0.
>    Application Order     2              2         2352     0.
>               Vector   617            582      1312048     0.
>       Vector Scatter    41             23        15088     0.
> In this example, the objects registered for destroy where also composed with l2g maps and scatters.
> So the user may think of having memory leaks somewhere. But running with -malloc_dump (or  under valgrind --leak-check=full) the output is clean.
> This is because PetscObjectRegisterDestroyAll is called after PetscLogView in PetscFinalize().
> What if the reason to call PetscObjectRegisterDestroyAll after PetscLogView? Just for having PETSC_VIEWER_STDOUT_WORLD available?
> Stefano
