[petsc-dev] How can we improve log_view about objects created and destroyed?
Barry Smith
bsmith at mcs.anl.gov
Thu Sep 7 16:00:39 CDT 2017
Example that produces this problem?
> On Sep 1, 2017, at 2:42 AM, Stefano Zampini <stefano.zampini at gmail.com> wrote:
> As it is now, if you create any object and use PetscObjectRegisterDestroy, the output from log_view may be misleading, as it will show something like this
> Memory usage is given in bytes:
> Object Type Creations Destructions Memory Descendants' Mem.
> Reports information only for process 0.
> --- Event Stage 0: Main Stage
> Index Set 237 237 310852 0.
> IS L to G Mapping 53 35 75260 0.
> Application Order 2 2 2352 0.
> Vector 617 582 1312048 0.
> Vector Scatter 41 23 15088 0.
> In this example, the objects registered for destroy where also composed with l2g maps and scatters.
> So the user may think of having memory leaks somewhere. But running with -malloc_dump (or under valgrind --leak-check=full) the output is clean.
> This is because PetscObjectRegisterDestroyAll is called after PetscLogView in PetscFinalize().
> What if the reason to call PetscObjectRegisterDestroyAll after PetscLogView? Just for having PETSC_VIEWER_STDOUT_WORLD available?
> Stefano
