[petsc-dev] c++, float128 and complex patch
    Satish Balay
    balay at mcs.anl.gov
    Thu Sep  7 10:26:33 CDT 2017
On Thu, 7 Sep 2017, Michael Gegg wrote:
> Thank you very much, that does it. One more question: Could you include this
> patch in the official petsc release in the future?
Yes - once tested in next - it would go into master - and next release
(3.8) of petsc.
I can also it to maint - which will go into next 3.7.7 patch
release.. [will have to backport - due to code changes between
maint/master]
Satish
> I would really appreciate
> that: I wrote a c++ library for quantum optical master equations based on
> petsc (https://github.com/modmido/psiquasp), which is available on github and
> sometimes extended precision is necessary (complex is mandatory). I now
> included a patch there, so that people can use this, but this is only a
> momentary fix.
> Thank you. Michael
> Am 06.09.2017 um 20:03 schrieb Satish Balay:
> > On Wed, 6 Sep 2017, Satish Balay wrote:
> > > > So, could you give me a hint on how I should configure petsc so that
> > > > this
> > > > works? Is there a way to enforce the c99 complex numbers even when
> > > > calling
> > > > petsc from c++?
> > > Perhaps this is the change you need?
> > Looks like I need one more change..
> > Satish
> > balay at asterix /home/balay/petsc (master *=)
> > $ git diff
> > diff --git a/include/petscmath.h b/include/petscmath.h
> > index a63f1f4977..a201c3093e 100644
> > --- a/include/petscmath.h
> > +++ b/include/petscmath.h
> > @@ -214,7 +214,7 @@ PETSC_EXTERN MPI_Datatype MPIU___COMPLEX128;
> >   #endif  /* PETSC_USE_REAL_ */
> >   #endif  /* ! PETSC_SKIP_COMPLEX */
> >   -#elif !defined(__cplusplus) && defined(PETSC_HAVE_C99_COMPLEX) &&
> > !defined(PETSC_USE_REAL___FP16)
> > +#elif defined(PETSC_HAVE_C99_COMPLEX) && !defined(PETSC_USE_REAL___FP16)
> >   #if !defined(PETSC_SKIP_COMPLEX)
> >   #define PETSC_HAVE_COMPLEX 1
> >   #include <complex.h>
> > @@ -414,7 +414,7 @@ PETSC_EXTERN PetscComplex PETSC_i;
> >   PETSC_STATIC_INLINE PetscComplex PetscCMPLX(PetscReal x, PetscReal y)
> > -#if   defined(__cplusplus)
> > +#if   defined(__cplusplus) && !defined(PETSC_USE_REAL___FLOAT128)
> >     return PetscComplex(x,y);
> >   #elif defined(_Imaginary_I)
> >     return x + y * _Imaginary_I;
