[petsc-dev] c++, float128 and complex patch
Michael Gegg michael.gegg at tu-berlin.de
Thu Sep 7 10:02:53 CDT 2017
Thank you very much, that does it. One more question: Could you include
this patch in the official petsc release in the future? I would really
appreciate that: I wrote a c++ library for quantum optical master
equations based on petsc (https://github.com/modmido/psiquasp), which is
available on github and sometimes extended precision is necessary
(complex is mandatory). I now included a patch there, so that people can
use this, but this is only a momentary fix.
Thank you. Michael
Am 06.09.2017 um 20:03 schrieb Satish Balay:
> On Wed, 6 Sep 2017, Satish Balay wrote:
>>> So, could you give me a hint on how I should configure petsc so that this
>>> works? Is there a way to enforce the c99 complex numbers even when calling
>>> petsc from c++?
>> Perhaps this is the change you need?
> Looks like I need one more change..
> Satish
> balay at asterix /home/balay/petsc (master *=)
> $ git diff
> diff --git a/include/petscmath.h b/include/petscmath.h
> index a63f1f4977..a201c3093e 100644
> --- a/include/petscmath.h
> +++ b/include/petscmath.h
> @@ -214,7 +214,7 @@ PETSC_EXTERN MPI_Datatype MPIU___COMPLEX128;
>   #endif  /* PETSC_USE_REAL_ */
>   #endif  /* ! PETSC_SKIP_COMPLEX */
> -#elif !defined(__cplusplus) && defined(PETSC_HAVE_C99_COMPLEX) && !defined(PETSC_USE_REAL___FP16)
> +#elif defined(PETSC_HAVE_C99_COMPLEX) && !defined(PETSC_USE_REAL___FP16)
>   #if !defined(PETSC_SKIP_COMPLEX)
>   #define PETSC_HAVE_COMPLEX 1
>   #include <complex.h>
> @@ -414,7 +414,7 @@ PETSC_EXTERN PetscComplex PETSC_i;
>   PETSC_STATIC_INLINE PetscComplex PetscCMPLX(PetscReal x, PetscReal y)
> -#if   defined(__cplusplus)
> +#if   defined(__cplusplus) && !defined(PETSC_USE_REAL___FLOAT128)
>     return PetscComplex(x,y);
>   #elif defined(_Imaginary_I)
>     return x + y * _Imaginary_I;
