[petsc-dev] How are we deciding the memory alignment that BuildSystem should choose?
    Jed Brown
    jed at jedbrown.org
    Tue Sep  5 12:55:25 CDT 2017
Richard Tran Mills <rtmills at anl.gov> writes:
> Folks,
> I am wondering how PETSc's BuildSystem currently chooses the memory
> alignment to use. In the example file I provide in the repo for the Cori
> KNL nodes, I specify '--with-memalign=64' to match the cache line width. If
> I don't do this, then configure chooses a 16 byte alignment. Do people
> think that we should try to make a better effort to choose a more
> appropriate alignment?
> I believe that all modern x86 CPUs use a 64 byte cache width, so should we
> be defaulting to that? I don't know how much this matters on a Xeon
> processor, but it can be important on Xeon Phi.
The preference for 16 was for SSE2, prior to AVX and AVX512.  With AVX,
I believe there is no particular reason to prefer more than 32-byte
alignment -- it just ensures that objects cannot share cache lines.
Harmless with large arrays, but not ideal for smaller allocations like
nodes in a linked list.  (PETSc doesn't use these very often, but it
would be nice if control structures don't soak up more cache than they
need.)
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170905/188ecbb9/attachment.sig>
