[petsc-dev] SLEPc failure
Franck Houssen franck.houssen at inria.fr
Sat Oct 28 06:11:52 CDT 2017
I just added that before EPSSetOperators:
PetscViewer viewerA; PetscViewerBinaryOpen(PETSC_COMM_WORLD,"Atau.out",FILE_MODE_WRITE,&viewerA); MatView(A,viewerA);
PetscViewer viewerB; PetscViewerBinaryOpen(PETSC_COMM_WORLD,"Btau.out",FILE_MODE_WRITE,&viewerB); MatView(B,viewerB);
At first, I avoided binary as I didn't know if the format handles big/little endianness... So I prefered ASCII.
Binary data are attached.
Franck
PS : running debian with little endian.
>> python -c "import sys;print(0 if sys.byteorder=='big' else 1)"
1
----- Mail original -----
> De: "Jose E. Roman" <jroman at dsic.upv.es>
> À: "Franck Houssen" <franck.houssen at inria.fr>
> Cc: "For users of the development version of PETSc" <petsc-dev at mcs.anl.gov>
> Envoyé: Vendredi 27 Octobre 2017 18:52:56
> Objet: Re: [petsc-dev] SLEPc failure
> I cannot load the files you sent. Please send the matrices in binary format.
> The easiest way is to run your program with -eps_view_mat0 binary:Atau.bin
> -eps_view_mat1 binary:Btau.bin
> However, the files are written at the end of EPSSolve() so if the solve fails
> then it will not create the files. You can try running with -eps_max_it 1
> or add code in your main program to write the matrices.
> Jose
> > El 27 oct 2017, a las 12:28, Franck Houssen <franck.houssen at inria.fr>
> > escribió:
> > Maybe could be convenient for the users to have an option (or an EPSSetXXX)
> > to relax that check ?
> > Data are attached.
> > Franck
> >> Envoyé: Vendredi 27 Octobre 2017 10:15:44
> >> There is no new option. What I mean is that from 3.7 to 3.8 we changed the
> >> line that produces this error. But it seems that it is still failing in
> >> your
> >> problem. Maybe your B matrix is indefinite or not exactly symmetric. Can
> >> you
> >> send me the matrices?
> >> Jose
> >>> El 27 oct 2017, a las 9:57, Franck Houssen <franck.houssen at inria.fr>
> >>> escribió:
> >>> I use the development version (bitbucket clone). How to relax the check ?
> >>> At command line option ?
> >>> Franck
> >>>> Envoyé: Jeudi 26 Octobre 2017 18:49:22
> >>>>> El 26 oct 2017, a las 18:36, Franck Houssen <franck.houssen at inria.fr>
> >>>>> escribió:
> >>>>> Here is a stack I end up with when trying to solve an eigen problem
> >>>>> (real,
> >>>>> sym, generalized) with SLEPc. My understanding is that, during the Gram
> >>>>> Schmidt orthogonalisation, the projection of one basis vector turns out
> >>>>> to
> >>>>> be null.
> >>>>> First, is this correct ? Second, in such cases, are there some
> >>>>> recommended
> >>>>> "recipe" to test/try (options) to get a clue on the problem ? (I would
> >>>>> unfortunately perfectly understand the answer could be no !... As this
> >>>>> totally depends on A/B).
> >>>>> With arpack, the eigen problem is solved (so the matrix A and B I use
> >>>>> seems
> >>>>> to be relevant). But, when I change from arpack to
> >>>>> krylovschur/ciss/arnoldi, I get the stack below.
> >>>>> Franck
> >>>>> [0]PETSC ERROR: #1 BV_SafeSqrt()
> >>>>> [0]PETSC ERROR: #2 BVNorm_Private()
> >>>>> [0]PETSC ERROR: #3 BVNormColumn()
> >>>>> [0]PETSC ERROR: #4 BV_NormVecOrColumn()
> >>>>> [0]PETSC ERROR: #5 BVOrthogonalizeCGS1()
> >>>>> [0]PETSC ERROR: #6 BVOrthogonalizeGS()
> >>>>> [0]PETSC ERROR: #7 BVOrthonormalizeColumn()
> >>>>> [0]PETSC ERROR: #8 EPSFullLanczos()
> >>>>> [0]PETSC ERROR: #9 EPSSolve_KrylovSchur_Symm()
> >>>>> [0]PETSC ERROR: #10 EPSSolve()
> >>>> Is this with SLEPc 3.8? In SLEPc 3.8 we relaxed this check so I would
> >>>> suggest
> >>>> trying with it.
> >>>> Jose
> > <ABtau.tar.gz>
Type: application/x-compressed-tar
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171028/2f54f53e/attachment-0001.bin>
