[petsc-dev] SLEPc failure
Jose E. Roman jroman at dsic.upv.es
Fri Oct 27 11:52:56 CDT 2017
I cannot load the files you sent. Please send the matrices in binary format. The easiest way is to run your program with -eps_view_mat0 binary:Atau.bin -eps_view_mat1 binary:Btau.bin
However, the files are written at the end of EPSSolve() so if the solve fails then it will not create the files. You can try running with -eps_max_it 1  or add code in your main program to write the matrices.
Jose
> El 27 oct 2017, a las 12:28, Franck Houssen <franck.houssen at inria.fr> escribió:
> Maybe could be convenient for the users to have an option (or an EPSSetXXX) to relax that check ?
> Data are attached.
> Franck
> ----- Mail original -----
>> De: "Jose E. Roman" <jroman at dsic.upv.es>
>> À: "Franck Houssen" <franck.houssen at inria.fr>
>> Cc: "For users of the development version of PETSc" <petsc-dev at mcs.anl.gov>
>> Envoyé: Vendredi 27 Octobre 2017 10:15:44
>> Objet: Re: [petsc-dev] SLEPc failure
>> There is no new option. What I mean is that from 3.7 to 3.8 we changed the
>> line that produces this error. But it seems that it is still failing in your
>> problem. Maybe your B matrix is indefinite or not exactly symmetric. Can you
>> send me the matrices?
>> Jose
>>> El 27 oct 2017, a las 9:57, Franck Houssen <franck.houssen at inria.fr>
>>> escribió:
>>> I use the development version (bitbucket clone). How to relax the check ?
>>> At command line option ?
>>> Franck
>>>> Envoyé: Jeudi 26 Octobre 2017 18:49:22
>>>>> El 26 oct 2017, a las 18:36, Franck Houssen <franck.houssen at inria.fr>
>>>>> escribió:
>>>>> Here is a stack I end up with when trying to solve an eigen problem
>>>>> (real,
>>>>> sym, generalized) with SLEPc. My understanding is that, during the Gram
>>>>> Schmidt orthogonalisation, the projection of one basis vector turns out
>>>>> to
>>>>> be null.
>>>>> First, is this correct ? Second, in such cases, are there some
>>>>> recommended
>>>>> "recipe" to test/try (options) to get a clue on the problem ? (I would
>>>>> unfortunately perfectly understand the answer could be no !... As this
>>>>> totally depends on A/B).
>>>>> With arpack, the eigen problem is solved (so the matrix A and B I use
>>>>> seems
>>>>> to be relevant). But, when I change from arpack to
>>>>> krylovschur/ciss/arnoldi, I get the stack below.
>>>>> Franck
>>>>> [0]PETSC ERROR: #1 BV_SafeSqrt()
>>>>> [0]PETSC ERROR: #2 BVNorm_Private()
>>>>> [0]PETSC ERROR: #3 BVNormColumn()
>>>>> [0]PETSC ERROR: #4 BV_NormVecOrColumn()
>>>>> [0]PETSC ERROR: #5 BVOrthogonalizeCGS1()
>>>>> [0]PETSC ERROR: #6 BVOrthogonalizeGS()
>>>>> [0]PETSC ERROR: #7 BVOrthonormalizeColumn()
>>>>> [0]PETSC ERROR: #8 EPSFullLanczos()
>>>>> [0]PETSC ERROR: #9 EPSSolve_KrylovSchur_Symm()
>>>>> [0]PETSC ERROR: #10 EPSSolve()
>>>> Is this with SLEPc 3.8? In SLEPc 3.8 we relaxed this check so I would
>>>> suggest
>>>> trying with it.
>>>> Jose
> <ABtau.tar.gz>
