[petsc-dev] test harness with alternative output files
Smith, Barry F. bsmith at mcs.anl.gov
Thu Oct 26 22:53:16 CDT 2017
  Scott,
    Thanks. Might be enough as is.
   Satish,
     Could you see if this support is enough to fix he pesky example in master nightly that produces two different possible output.
   Barry
> On Oct 26, 2017, at 10:48 PM, Scott Kruger <kruger at txcorp.com> wrote:
> On 10/25/17 10:04 AM, Smith, Barry F. wrote:
>>    Scott,
>>     It looks like you started to put in support for the test harness to compare output against multiple files.
>> $ git grep altfile
>> config/gmakegentest.py:    if len(altlist)>1: subst['altfiles']=altlist
>> config/gmakegentest.py:      if 'altfiles' not in subst:
>> config/gmakegentest.py:        for i in range(len(subst['altfiles'])):
>> config/gmakegentest.py:          af=subst['altfiles'][i]
>> config/gmakegentest.py:          if i!=len(subst['altfiles'])-1:
>> but that there is not yet support for this?
> There is support but:
> 1. It requires the multiple files to be of the form ex*_[1-3]_alt.out
>   in the output directory
> 2. It is piping all of the diffs simultaneously to create a single
>   diff test rather than multple.
> You can look at a $PETSC_ARCH/tests/src/sys/examples/tests/runex2.sh to see how this works.
> I assuming that you would rather:
> 1. Have an altfiles (or similar) keyword (*)
> 2. Have separate difftests for each.
> Scott
> (*) see documentation or the top of config/testparse.py for accepted keywords currently
>> We have a bunch of tests that require this so we will need it in the test harness. How difficult do you think this would be to add?
>>    Thanks
>>    Barry
> Tech-X Corporation               kruger at txcorp.com
> 5621 Arapahoe Ave, Suite A       Phone: (720) 974-1841
> Boulder, CO 80303                Fax:   (303) 448-7756
