[petsc-dev] type(*) not supported by multiple test fortran compilers we use
    Jed Brown
    jed at jedbrown.org
    Thu Oct 26 07:55:27 CDT 2017
Which compilers don't work?
"Smith, Barry F." <bsmith at mcs.anl.gov> writes:
>    Jed,
>     Unfortunately multiple fortran compilers we use do not support type(*) so we either configure check this stuff (annoying) or stop supporting lots of Fortran compilers.
>    Satish,
>        I guess you need to check all the failed Fortran compilers and see if they have versions that work that uses can also access easily. For example what if the absoft compiler product does not support it?
>    Barry
