[petsc-dev] Improving nightly builds for maint
    Jed Brown
    jed at jedbrown.org
    Fri Oct 20 13:12:51 CDT 2017
Barry Smith <bsmith at mcs.anl.gov> writes:
>> On Oct 18, 2017, at 3:10 PM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
>> On 18 October 2017 at 22:36, Satish Balay <balay at mcs.anl.gov> wrote:
>>> On Wed, 18 Oct 2017, Lisandro Dalcin wrote:
>>> Alternate is to remove/increase the timout. It doesn't work for some
>>> builds anyway [esp valgrind runs]
>>> This feature relies on sending 'kill' message to the process it
>>> started - i.e mpiexec. But some mpiexecs when killed - don't kill the
>>> child processes cleanly]
>>> $ git diff |cat
>>> diff --git a/bin/maint/buildtest b/bin/maint/buildtest
>>> index 31b5a3a028..e4bbf96db8 100755
>>> --- a/bin/maint/buildtest
>>> +++ b/bin/maint/buildtest
>>> @@ -104,7 +104,7 @@ if ( $? ) then
>>> else
>>>   set VALGRIND=`echo MPIEXEC="${PETSC_DIR}/bin/petscmpiexec -valgrind"`
>>>   setenv PETSCVALGRIND_OPTIONS "--suppressions=${PETSC_DIR}/bin/maint/petsc-val.supp"
>>> -  set TIMEOUT=720
>>> +  set TIMEOUT=7200
>>> endif
>> No, please don't!  Be green, Satish!
>> What's the point of running a 3D problem under valgrind for 2 hours?
>    Find memory corruption bugs that won't be found otherwise?
So use three elements and two time steps.
>    But note that the original test problems should be taking only a short time so even with valgrind should not take 2 hours.
Yes.
