[petsc-dev] Improving nightly builds for maint
Barry Smith
bsmith at mcs.anl.gov
Fri Oct 20 11:35:12 CDT 2017
> On Oct 18, 2017, at 3:10 PM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> On 18 October 2017 at 22:36, Satish Balay <balay at mcs.anl.gov> wrote:
>> On Wed, 18 Oct 2017, Lisandro Dalcin wrote:
>> Alternate is to remove/increase the timout. It doesn't work for some
>> builds anyway [esp valgrind runs]
>> This feature relies on sending 'kill' message to the process it
>> started - i.e mpiexec. But some mpiexecs when killed - don't kill the
>> child processes cleanly]
>> $ git diff |cat
>> diff --git a/bin/maint/buildtest b/bin/maint/buildtest
>> index 31b5a3a028..e4bbf96db8 100755
>> --- a/bin/maint/buildtest
>> +++ b/bin/maint/buildtest
>> @@ -104,7 +104,7 @@ if ( $? ) then
>> else
>> set VALGRIND=`echo MPIEXEC="${PETSC_DIR}/bin/petscmpiexec -valgrind"`
>> setenv PETSCVALGRIND_OPTIONS "--suppressions=${PETSC_DIR}/bin/maint/petsc-val.supp"
>> - set TIMEOUT=720
>> + set TIMEOUT=7200
>> endif
> No, please don't! Be green, Satish!
> What's the point of running a 3D problem under valgrind for 2 hours?
Find memory corruption bugs that won't be found otherwise?
But note that the original test problems should be taking only a short time so even with valgrind should not take 2 hours.
Barry
> I think we should somehow support
> requires: !valgrind
> and add special code in the test harness (maybe using some environment
> var?) to skip running these tests...
> Lisandro Dalcin
> Research Scientist
> Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
> Extreme Computing Research Center (ECRC)
> King Abdullah University of Science and Technology (KAUST)
> http://ecrc.kaust.edu.sa/
> 4700 King Abdullah University of Science and Technology
> al-Khawarizmi Bldg (Bldg 1), Office # 0109
> Thuwal 23955-6900, Kingdom of Saudi Arabia
> http://www.kaust.edu.sa
> Office Phone: +966 12 808-0459
